OK gang, I bougt a 2000 SVT on ebay and will be going to pick it up in a couple of weeks for a 1,000 mile "honeymoon" roadtrip home. The car has 104k on her.
I have time to mail myself some parts and tools for the trip. I had in mind to send a serpentine belt, WP belt and NAPA WP. Radiator hoses and clamps.
Having not spent any time under the hood yet, what size whenches and sockets would be good to have along? I assume 10-15mm would cover most needs, but wanted to get some input from the pros.
Thanks!
Carl 2000 Black CSVT #415 89 SHO (RIP) 75 280z
I
I
make sure you have 7mm and up.
check the how-to and other FAQ
http://www.contour.org/mods/mods.php?s=howto
also 3" and 6" extension would also help.
you might also want to bring 6 autolite or motorcraft spark plugs just in case (look up info on FAQ, how-to for part #'s and direction) and plug wires, since you'd probably want to change those anyway for maintenance. when you pick up the car i'd pick up some coolant, water, oil, etc.
good luck with the purchase, and make sure you test drive it a while before heading out on your long trip.
but in any case, check the FAQ, it tells you what tools you'd need,etc.
00 CSVT #390
9
APP764 is the Autolite plug number.
I carry a small craftsman toolset. Seems to work well for most things. IIRC it was around $30.
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
