Page 3 of 3 1 2 3
Originally posted by 2112:
When the secondary shafts are removed, how are you plugging the guide holes for the shafts themselves?
Actually I used a couple of small bolts with JB Weld to plug the shaft holes. My IMRC cable is rigged to a return spring out of the way to avoid the MIL. Nothing else "needed" to avoid a MIL, but adding a little fuel down low is nice.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
I have looked everywhere and can not find it. could someone tell me where the how to for removal of the UIM is so I can remove the secondaries alltogether. My IMRC cable broke and I have them pinned and decided to just remove them. My SVT is chipped and likes them open a lot.
98 EO #587
Currently Dirt Jumping
The "how-to" is where they are...
The FAQ laugh
Wavrdr - the "Chip" programming I was talking about it setting the IMRC point extremely low (2500rpm) and running a return spring (like Brad)
This way the PCM gives me the fuel & timing advance down low and I don't get the CEL from having to have it think they (secondaries) are always open.
The only way I could get my current program to give me timing advance down low is to pin them open and either reset the CEL each time I started up (the CEL only cuts a little fuel when chipped - cuts both fuel and timing hard when not chipped) or just run with the CEL (which is what I normally did)
2000 SVT #674 - Check it out!
I did exactly what Gator said, cut down the shafts and reinstall them, so that the spring mechanism still works with IMRC to keep that darn CEL off. wink
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Ok, went through every page in the FAQ and guess what...It's not there laugh
98 EO #587
Could someone tell me where the how to for removal of the UIM is so I can remove the secondaries alltogether.
Read the FAQ, many of your questions will be answered here!
1991 GVR4
Lots of mods done.
Thanks, didn't mean to put anyone through too much trouble.
98 EO #587
Page 3 of 3 1 2 3
