Posts: 3,562 |
Originally posted by 2112: When the secondary shafts are removed, how are you plugging the guide holes for the shafts themselves? Actually I used a couple of small bolts with JB Weld to plug the shaft holes. My IMRC cable is rigged to a return spring out of the way to avoid the MIL. Nothing else "needed" to avoid a MIL, but adding a little fuel down low is nice.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 414 |
I have looked everywhere and can not find it. could someone tell me where the how to for removal of the UIM is so I can remove the secondaries alltogether. My IMRC cable broke and I have them pinned and decided to just remove them. My SVT is chipped and likes them open a lot.
98 EO #587 Currently Dirt Jumping
Posts: 7,329 |
The "how-to" is where they are... The FAQ Wavrdr - the "Chip" programming I was talking about it setting the IMRC point extremely low (2500rpm) and running a return spring (like Brad) This way the PCM gives me the fuel & timing advance down low and I don't get the CEL from having to have it think they (secondaries) are always open. The only way I could get my current program to give me timing advance down low is to pin them open and either reset the CEL each time I started up (the CEL only cuts a little fuel when chipped - cuts both fuel and timing hard when not chipped) or just run with the CEL (which is what I normally did)
Posts: 3,237 |
I did exactly what Gator said, cut down the shafts and reinstall them, so that the spring mechanism still works with IMRC to keep that darn CEL off.
Posts: 414 |
Ok, went through every page in the FAQ and guess what...It's not there
Posts: 4,319 |
Originally posted by 2112: Could someone tell me where the how to for removal of the UIM is so I can remove the secondaries alltogether. Originally posted by 2112: Ok, went through every page in the FAQ and guess what...It's not there Read the FAQ, many of your questions will be answered here!
1991 GVR4 Lots of mods done.
Posts: 414 |
Thanks, didn't mean to put anyone through too much trouble.
