#116333 03/27/02 09:46 PM
I
Ianthin Offline OP
I
Does anyone have any info adapting the Mustang 4.6 Timing adjuster kit for use on Duratech engines? The kit re-locates the crank sensor to an adjustable bracket. A new trigger wheel is bolted to the ballancer. Then you can change base timing to inprove overall performance. This would be an inexpesive improvement for any N2O/SC install, plus added power for NA motors as well.
Your thoughts please.
#116334 03/28/02 10:13 PM
Administrator
Administrator
Who makes this? Where is this info?
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#116335 03/28/02 10:22 PM
Steeda . It won't work with the Contour because of the difference in number of counts per revolution, but the "idea" could work...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#116336 03/29/02 01:10 AM
Administrator
Administrator
Actually, if the number of timing notches are the same, it should work. TDC is TDC according to the ring. Special notch for TDC. Investigation continues.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
