Posts: 362 |
Ok well ever since I bought my 98 CSVT I have suspected that the speedo was off by a bit because it said I was going faster than it felt. Recently I confirmed it because I bought a GPS that also tracks my MPH and my speedo seems to be off between 6-7 MPH everywhere. I thought that was kinda weird since it is the same amount off no matter how fast I was going so I am kinda confused as to what it could be that is causing that. The only thing I can think off is perhaps the need skipped one of the teeth that it sits in, but I dunno.
Any other suggestions? Thanks guys
2001 Volvo S40-Perrin MBC@ 11psi, EST intake, 35% tint, still slow
Posts: 285 |
If you have tires that are larger or smaller than stock it can cause the difference.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
Posts: 362 |
Yes, but two things.....
First off my tires are still stock size
Secondly, it would not be 6-7 MPH off everywhere it would be a ratio therefore the faster you are going the more MPH it is off
Posts: 5,143 |
just have the speedo recalibrated, its not that difficult/expensive... My speedo is off by 3 MPH. Doesnt bug me though. Just means when I think im going 35, im actually going 32... Makes it harder to get a speeding ticket
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 362 |
Yea I guess it doesn't really bother me that much and I know how much it is off....but i just figured if it was something easy to fix I would do it that way it was accurate again.
Thanks for the input
Posts: 4,140 |
If it is off by the same amount all the time, then just adjust the needle. It's when it's off by a few % (relative to speed) that you have to recalibrate, such as with non-stock tires.
Posts: 362 |
Yea I figured that I would just adjust the needle if I ever get some ambition. Its way too cold here right now to even think of working on my car.
