Posts: 1,336 |
I couldn't pass this deal up ... new list memeber. Deposit made online
Posts: 225 |
Originally posted by NVSVT: Latest list of who is in:
NVSVT (2) ââ?¬â?? deposit made DarKSidE ââ?¬â?? deposit made 96BlackSE ââ?¬â?? maybe JEDsContour ââ?¬â?? deposit made Docfeelgood111 - deposit mailed 02/01/2005 R_G ââ?¬â?? deposit made BDSVT ââ?¬â?? deposit made Ronan ââ?¬â?? definitely (ready with deposit) TourDeForce ââ?¬â?? deposit made Shaggy - definitely (ready with deposit) ohsigmachi - deposit made 00SVTGA - deposit made scottd60 - maybe morbid - deposit made DanCanuck - deposit mailed 01/29/2005 goalcoach - deposit made EternalOne - maybe 95SE_ATL - deposit made eepals - deposit made Aspire - maybe fastcougar - deposit made
I received a question from SF-SVT and I felt it would be beneficial to post it here along with Rick�s reply.
"I'm just curious about this sub-frame. I have a 1998.5 SVT and I have tried many times to reinforce the brackets; does your sub-frame address the issue of different sized fuel tanks for different production years? If I recall correctly, on the 1998.5 and earlier cars there was a fitment issue with the driver-side mount because the fuel tank was very, very close to the stock 'hook' bracket and the weld-on plate won't fit unless the end is filed down almost to the mounting hole. I might be interested in this group buy if the sub-frame addresses this issue.
Thanks, SF-SVT"
"The very first one we installed was on an early model and the fuel tank was very close to the sway bar brackets, so I understand your concern. When we build these we hold to the factory sway bar mounting dimensions and I think in the picture you can see that both the outside corners are cut at an angle to provide as much clearance as possible. I believe that the modified sub-frame should clear without issues. That being said, with production tolerances as they are, I can see where there may be some minor modification required in some instances. I also believe there is some room for the sub-frame to move forward and back when bolted in place.
Best regards, Rick Myers Division Manager ATI Performance Engineering 47199 Cartier Drive Wixom, MI 48393 USA"
ALL DEPOSITS MUST BE IN BY FEBRUARY 4TH AND YOUR REMAINING PAYMENT MUST BE MADE BEFORE THE SUB-FRAME SHIPS, BUT NO LATER THAN MARCH 4TH.
The Original Owner of 1998 SVT Contour #3384 of 6535,
Toreador Red/Midnight Blue, Assembled September 3rd, 1997
Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed,
Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
Posts: 1,423 |
I'm in...deposit made today online.
Thanks
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 3 |
Deposit has been made.
Posts: 225 |
NVSVT (2) ââ?¬â?? deposit made DarKSidE ââ?¬â?? deposit made 96BlackSE ââ?¬â?? maybe JEDsContour ââ?¬â?? deposit made Docfeelgood111 - deposit mailed 02/01/2005 R_G ââ?¬â?? deposit made BDSVT ââ?¬â?? deposit made Ronan ââ?¬â?? definitely (ready with deposit) TourDeForce ââ?¬â?? deposit made Shaggy - definitely (ready with deposit) ohsigmachi - deposit made 00SVTGA - deposit made scottd60 - deposit made morbid - deposit made DanCanuck - deposit mailed 01/29/2005 goalcoach - deposit made EternalOne - deposit made 95SE_ATL - deposit made eepals - deposit made Aspire - maybe fastcougar - deposit made vodfan - deposit made 04marauder - deposit made
Posts: 7,117 |
WOW!!! 20 subframes so far. I never would have been this optomistic! Are there even 20 new subframes in the U.S.??
Posts: 5,621 |
Originally posted by TourDeForce: Are there even 20 new subframes in the U.S.??
Posts: 225 |
Originally posted by TourDeForce: WOW!!! 20 subframes so far. I never would have been this optomistic! Are there even 20 new subframes in the U.S.??
I sure hope so!!
I'm shocked at the response to this group buy. When I started this I was hoping for (4) additional buyers, but we are at (18) and it isn't over yet!!!
Thanks to all of you for your support.
Posts: 7,117 |
Those who will be looking for a snazzy new rear sway bar to add to their new subframe - There is a group buy for highly sought after Aussie bars getting warmed up. Check it out!
I expect the Aussie bar buy to start about the time this one ships out it's last subframe, so there may be time to save up some additional cabbage (or sell some spare parts - like side skirts for my T-red SE (hint, hint)) & get an authentic Aussie bar!
Posts: 5,882 |
NVSVT check yo PM yo. just deposited my deposit in the deposit section on ATI's sizzite! now just need an Aussie bar!
