Try here: "http://www.alldata.com/TSB/19/95194179.html" or a Google search like "1995 Ford Contour Recalls".
Fairly sure issue #1 applies to all 2.0 liter cars, look for what looks like a heat-sink with fins right where the wires connect to the fan, if you see it then the work has been done already.
Issue #2 only applies if the wires fail inspection, meaning there is visable cracks in the under hood wiring harness.
Issue #3 is wear and tear, if your's is burnt you buy a new one at the dealer for about $20-25.
Also, you can call your local Ford dealer and they will have records of any recall work already done on your serial number.
