Posts: 363 |
You guys forot about option 4 wiring. Positive wire from side marker goes to positive on blinker. Negative wire from marker goes to positive on parking lights. I can't explain why this works, but the marker light will light up when your headlights are on AND will blink when the turn signal is on, but will blink opposite to your front/rear turn signals.
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 14 |
You can see the side light markers at this web site. The cost at Pep Boys was $19.95. http://www.brandsport.com/apc-40255277.htmlI decided the LEDs were a bit to much, but they are an option if you like them. The pre-wired bulb holders for the VW are sold separate from the side light lens and slide into the back of the side lights. Rick
Posts: 89 |
So how does option 3 work with no ground?
Posts: 4,294 |
more install stuff here
picture that used to be floating around.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 96 |
pug-
i am wondering the same thing. my very limited electrical knowledge has led me to conclude that apparently the factory ground is able to handle the addition of low power side markers with no problem.
weasel-
thanks for the additional variation. it is the one i will use.
audiotour-
thanks very much for posting the schematic. it will be invaluable as it shows me wire colors i must work with. appreciate it!
wish me luck all- i will tackle this little project early in the coming week. i now have much more confidence in my being able to do this correctly and not screw up! lakeside
on a lake in middle tn
'98 mystique ls duratec atx
de-badged, pin striped
pre '98 sail panels
b pillar black out mod
silverstars- turns and highs in lows
fogs on with parking lights mod
Posts: 685 |
oh hell..i thought it was just a matter of splicing into a wire or two, didnt realize you have to put in resistors and other crap too. Might need to just drop this idear and not do the side markers .
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
Posts: 2,426 |
Originally posted by weasel: You guys forot about option 4 wiring. Positive wire from side marker goes to positive on blinker. Negative wire from marker goes to positive on parking lights. I can't explain why this works, but the marker light will light up when your headlights are on AND will blink when the turn signal is on, but will blink opposite to your front/rear turn signals.
Sounds to me like 3 and 4 are the same thing.
Posts: 4,294 |
Originally posted by mygameisplatnum: Originally posted by auiotour:  more install stuff here
its very easy, all you need to do is add a resistor, the show two but, one should be fine, just make sure to get the right value.
95 SES Sold
99 SE Sport Sold
Posts: 685 |
what exact type of resistors do we need then (id rather put two in to be safe), and where can we get them?
Also whats that diode thing? We need one of those too? What is the exact kind of diode and also where to buy?
Thanx
Justin
Posts: 857 |
Originally posted by wa2tuff: Originally posted by weasel: You guys forot about option 4 wiring. Positive wire from side marker goes to positive on blinker. Negative wire from marker goes to positive on parking lights. I can't explain why this works, but the marker light will light up when your headlights are on AND will blink when the turn signal is on, but will blink opposite to your front/rear turn signals.
Correct, 3 and 4 are the same thing. It works because when the blinker turns on, 12 volts is applied to the "ground" side of the sidemarker. But with the 12 volts already applied to the "hot" side of the sidemarker, the voltage difference across the lamp is 0, so the lamp is off. Technically this isn't the proper way to do it but the current draw is low enough to not really matter.
As for which ground, any will do. It's good practice to keep it on the same circuit as the lights though.
The writeup yields something between options 1 (On with running lights/NO blinker) and 2 (NO running lights/WITH blinker); the side markers are dimly on with the parking lights, and full-on in-sync with the blinkers. Here's a video of the behavior, and a closeup of the sidemarker.
You can leave out the electronic components and just splice the sidemarkers to the turn signal. This is easier, but you get a simpler behavior.
Originally posted by mygameisplatnum: what exact type of resistors do we need then (id rather put two in to be safe), and where can we get them?
I got mine at a surplus electronics parts store, but radio shack will probably have something that will work. Two is not "safer" than one; it's just a way to use available parts. For example, you need 20-ohms but if your store only has 10-ohm resistors in that wattage, you can connect them in series (10 + 10 = 20).
The diode prevents current from flowing the wrong way. You will need one for each side of the car.
The A6 sidemarkers are rectangular with amber lamps and uncolored frosted lenses. If you want clear lenses with the bulb cap, check with the VW/Audi parts guy. It'll probably work since the reflectors are all similar sizes.
