Page 3 of 3 1 2 3
#1160814 01/22/05 11:21 AM
Be sure to check BAT for sidemarker lights too, as they have the OEM lights from the Mondeo. They are oval and blend in better with the car's lines than a square-ish light, IMO. Their amber light is OEM, but the clear and smoked ones are aftermarket and the quality isn't quite as good. I originally bought the clear ones, but ended up ordering the amber ones 'cause the clear were kinda cheap-looking. The bulb color was really lame in the clear ones as well, although a new bulb easily fixed that.
As a side note, the sidemarker lights on Steve Saleen's supercar at SEMA looked exactly like the Mondeo lights. Closer to reality, the sidemarker lights on the wide rear fenders of dually F-series trucks may be the same light as well. I haven't looked closely yet, but seeing one on the road, the proportions were pretty close...
Side note two: The Mondeo lights use the same connector as many of Ford's fuel injectors. A friend gave me an old (early 90's?) Mustang injector harness and the connectors snapped right on! Cut the connector off, tore it apart and soldered new wires onto the terminals, reassembled it -- viola! Spiffin' waterproof connector assembly!
Marty
98 SVT, Black, No. 786, May 7, 1997. K&N, MSDS, Xcal2, Tint, Antennas, Big Gulp(R)-Sized Cupholder, Rear Dome Lt., Koni/Eibach, DMD, Pre-98 Sails, Brake Cooling Deflectors, Sidemarkers, Etc. 147K+ Miles "Get the Door - It's GrooveNerd!"
#1160815 01/22/05 07:52 PM
Is it really neccessary to solder the resitiors and diodes in, or can they be put in then taped and heat shrink wrapped?
#1160816 01/22/05 11:07 PM
Originally posted by weasel:
You guys forot about option 4 wiring. Positive wire from side marker goes to positive on blinker. Negative wire from marker goes to positive on parking lights. I can't explain why this works, but the marker light will light up when your headlights are on AND will blink when the turn signal is on, but will blink opposite to your front/rear turn signals.
So you're talking about just like the front side parking lights on most GMs... I noticed they do that on nearly all of them.
Simon (original owner) put APC dual filament sidemarkers on this car. They come on with the parking lights and flash with the turn signals. From what I saw, there were 2 resistors (with ceramic insulation) and a diode.
He also used the niteshades (or similar) on them, they look very nice.
I'm pretty sure the resistors are there just to keep the lights from flashing fast, right?
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1160817 01/22/05 11:11 PM
No, the resistors make the sidemarkers glow at half-bright when the parking lamps are on. Dual filament lamps are something else altogether and require different wiring.
E0 SVT, lightly modded
#1160818 01/22/05 11:23 PM
Originally posted by louisw:
The diode prevents current from flowing the wrong way. You will need one for each side of the car.
what kind or size diode do you need? Not very savy w/ kinda stuff so I dunno if they come in watts, ohms,(or don;t come in either) and you need a certian type?
Thanx
Justin 98.5 CSVT # 4887 of 6535 (born 2/28/98)
#1160819 01/22/05 11:32 PM
Diodes are specified by two values, max voltage and max current. The max voltage is just the car voltage, so anything above 15 volts is fine. The sidemarker uses a 194 lamp, which is typically 5-10 watts, which means at max the bulb will draw about 0.8 amps (I = P/V => 10/12 (idle voltage)). So anything above that is fine.
#1160820 01/22/05 11:45 PM
thanx louis for all you help an descriptions....now I can go atempt this install since I think all the bases have been covered
Page 3 of 3 1 2 3
