Posts: 4,292 |
here is the picture of a y pipe, can someone please tell me what kind it is? the seller tells me its a sho shop? bu when i look at my exhaust there is no way that this thing will fit
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 6,760 |
Why won't it fit? And it looks like the SS Unit.
Ryan
Trollin!
Posts: 4,292 |
i would if i removed the y pipe and put a piece of straight pipe in there, the thing is i'm in new york and they have the new emissions inspections now, and my precat are already gutted so i need the cat to pass the test
Posts: 6,760 |
So, um what does that have to do with the ypipe? And that thing the two pipes go into is the Main cat.
Ryan
Trollin!
Posts: 4,292 |
ok, i get your point,i found some pictures of the stock exhaust,and i guess if i take that nasty looking flex pipe off and have a flange welded on the end of the y pipe it should fit
Posts: 6,760 |
The 'nasty' flex pipe is there for a reason...it flexes...
Ryan
Trollin!
Posts: 291 |
The flex pipe was used from 99 onwards (IIRC). Early cars used the "doughnut" style connection. I've had both types on my car and I HATED the sound from the flex type connector. Apparently, the doughnut style connector was replaced for emissions reasons-it leaks. My guess is that Ford also found a way to make it more "cost-effective" (aka: cheaper).
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
MOst cars from ford have the stupid dognout style nonsense before what 99 or soo. my 92 sho now has a flex pipe going to a dynomax cat back. it does its job. Thats for sure
Posts: 87 |
My '96 SE has a flex pipe similar to the one you have in the picture. That part is original to the car and is standard production V6 fare. The assembly you have is definitely aftermarket, it appears to be an SHO shop version, but the heat shielding looks a bit different, it kind of looks like a BAT.
'96 SE 2.5 V6 ATX, Willow Frost Metallic
10-hole '84 Mustang 15x7 wheels w/ Dunlop 225/50-15's
CSVT air intake components with K&N cone filter
Optimized TB
Gutted Pre-cats w/MIL eliminators
Posts: 1,746 |
I don't think thats the BAT pipe.
