The black one just routes air from the fender well behind the fender liner. My bat remote air kit showed up tonight, but i didn't get around to doing the hose. The bat kit is designed to route air from the bumper directly into the end of the filter.
There is a baffle of some sort on the fender side that you can pull out and still leave the underhood part attached. A tleast i believe there is, but i don't have an svt. I know there is one on my SE.
But to answere the would this do any good question, probably not much. I have been logging the intake temperature signal and even on my stock se it was dropping close to ambient temp (prob 15 degrees above ambient) even at moderate speed (35-45 mph) and climbing back up when stopped or slowed. So in short once the car starts moving you are pulling rather cool air in anyway. But i'll post my findings once i get the hose routed.
98 SE BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B. ====OnOrder==== svt uppers and lowers,
