Posts: 110 |
Ok, I have a question that maybe some people have had similar problems with. 1998 Contour SE with the 2.5 V6 and automatic(no ABS or traction control) with 205/60/R15 Dunlop SP Sport A2's These tires on tirerack (fronts are new as of this summer, rears are half gone) (The folowing is on paved roads that have been plowed with a light layer of snow). When driving up hills there is no traction. I can understand that, having no snow tires on her. But on even the slightest incline i cant even get enough traction to get enough speed to make it up the roads. I barely touch the gas and just spin. I lift off the gas to let the wheels stop spinning and nothin. Even when i use second gear or use the brakes and gas slightly to prevent wheel spin all i do is spin. Its so frustrating. ![](/ubbthreads/images/graemlins/mad.gif) I have to almost take someone with me so they can get out and push. Any help or sugestions or others that have had similar experiences whould help very much. And there is no such thing as not driving up the hills here because thats all there is. Thank you in advance.
" 90 percent of all chevys are still on the road.
The other 10 made it home "
98 se, 2.5 V6,black,ATX
Cleared and silverstared, Hella Optilux, resonatorless, Kumho ECSTA 716s and Dunlop SP Sport A2s
Learned patience the hard way
Posts: 2,454 |
Might try dropping the pressure a little. If you've got them up to 40 psi for summer spirited driving they going to be a little hard to flex enough for traction in this cold weather. Beyond that it sounds like just crappy tires.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 110 |
I also forgot to mention that my car seems to ride a bit low in front. Do most people have a noticeable height difference between the front and the rear on thier tours? Ive had the springs in back replaced because they were broken. Could the front be the same? And could this be part of the problem? Thanks again
Posts: 610 |
actually...the front should look almost ready for 4 wheeling.
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 2,100 |
Originally posted by backinblack98: 205/60/R15 Dunlop SP Sport A2's
Ahhh found your problem.
I ran with those for tires for 2 years (2 sets) and they are only ok in snow. Replaced this summer tells people nothing. If I replace tires in the summer I would have about 20,000 miles on them by now.
Beaten - 2003 MazdaSpeed Protege 29K <- broken hearted
Daily/Weekend Beater - 1990 miata 138K - AutoX every weekend = Adult driven on weekends
Posts: 110 |
ok, thanks for the help. ill take a look at the springs and try lowerin the pressure.
Posts: 1,356 |
Originally posted by Buckshot77: Might try dropping the pressure a little. If you've got them up to 40 psi for summer spirited driving they going to be a little hard to flex enough for traction in this cold weather. Beyond that it sounds like just crappy tires.
Rick
I always though you were better off running a higher pressure in the winter, giving you a smaller contact area and more pressure on what does contact the ground.
Aren't skinny (width) tires better in the snow??
Now in the summer, if all you're after is grip you usually run them a little low (More contact area, better grip because the rubber grips the pavement) If its trying to grip snow/slush you want it to have more pressure, forcing the snow/slush out of the contact path.
I could be wrong though, in which case, correct me!
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
