#1153170 01/12/05 04:28 PM
what would trigger them??
mine just turned on but everything seems to be fine.
will it illumintate if pads are worn down??
#1153171 01/12/05 04:31 PM
I think that means the ABS isnt working. Check your fuses.
#1153172 01/12/05 05:05 PM
The ABS fault light doesn't indicate thin brake pads.
It does indicate something is wrong in the ABS system, such as a sensor problem, or pump problem. Get it checked out.
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
#1153173 01/12/05 08:19 PM
I've had this happen a few times to me, but that was when i had the zetec. Did you slide causing the ABS to engage then the light came on? When my abs kicked in, it blew the fuse every time.
1989 Toyota Corolla (Totaled, now father car) 1990 Isuzu Trooper (Sold for more than bought) 1998 Ford Contour SE (Totaled in moutains) 1990 Toyota Supra (Blown head gasket) 1998 Ford Contour SVT (So far so good ::knocks on wood::)
