Posts: 2,163 |
I am thinking about changing the power steering fluid in the resevior of my car a few times over the next several months to get clean fluid in there. I have never purchased power steering fluid before. Is it thru it is simply labeled as power steering fluid or should I use something else?
Posts: 10,015 |
Our cars do NOT use power steering fluid. They Use Mercon ATF, like in Auto trannys.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,693 |
You can also use synthetic Mercon. Mobil 1 ATF is Mercon approved and there are probably products from Red Line and Amsoil that qualify as well.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 101 |
WHOA!!! SAY WHAT?!?!? I've been using PS fluid now fpr 3 years... you saying i've been using the wrong stuff this whole time? My system never leaked or went bad, so what will I gain by using Mercon ATF fluid?
~~~ 99 Contour SE ATX 2.0 ~~~
~~~ 98 Mystique GS ATX 2.0 ~~~
~~~ 94 Civic DX HB MTX 1.5 ~~~
~~~ 91 Toyota MR2 MTX 2.2 ~~~
Posts: 313 |
As with any auto fluid, don't just buy what's on the shelf: Read your owner's manual!
Also note that early Contours (95 and 96, IIRC) actually call for Type F (an older forumulation of ATF; it's getting harder to find). Use the search to find out more on this topic.
1995 Contour GL V6 ATX T/C
1986 Mustang GT 5.0
2000 Windstar LX
Posts: 13 |
You can use power steering fluid also their virtually the same thing and the book says you can use either or
Posts: 6 |
Originally posted by Stazi: Our cars do NOT use power steering fluid. They Use Mercon ATF, like in Auto trannys.
PS fluid works just fine.
Posts: 6 |
Originally posted by phil: As with any auto fluid, don't just buy what's on the shelf: Read your owner's manual!
My 96 used PS fluid too. Not sure where you're getting the type F from.
Posts: 6,910 |
Originally posted by bigbenny358: Originally posted by phil: As with any auto fluid, don't just buy what's on the shelf: Read your owner's manual!
Type F is a kinda of ATF fluid that is suppose to be used in the 95s
- 95 Mystique LS - Zetec/5spd
Posts: 9,602 |
All Contiques require ATF (Type F or Mercon) in the power steering system.
I run Mobil 1 ATF.
2000 SVT #674
13.47 @ 102 - All Motor!
