Posts: 1,505 |
hi i was wondering if anyone has ever did a radiator flush on a zetec engine? we havent done ours we had the car since 29k not it has 112k and i know its time for one. does anyone know how to do this? thanks oh its a 99 zetec
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 6,910 |
take the thermostat out and disconnect the lower radiator hose as well as open the pepcock on the radiator
once the coolant is drained you can run water through the system at the thermostat until it comes out the lower hose clean water, button it up and call it a day
that should work pretty good, otherwise take it to a place and they can do it with a powered system, might be the only thing that will do it better
- 95 Mystique LS - Zetec/5spd
Posts: 1,505 |
you know how much that runs to take it to the shop? and also the colant container all brown any ideat how to get it out?
Posts: 3,065 |
The coolant conatiner comes right out, search to find how.
Posts: 1,231 |
TIP OF THE DAY: get a haines manual, they are handy!
95 Merc Stique
Zetec 2.0 Auto
Posts: 1,505 |
doesnt tell you jack [censored] im talking about the dirt looking stuff in the coolant container it's like hard dirt pppppphhhhhhhhhhhhhhh tip of the day get a haynes manual, they are handy!
Posts: 6,910 |
Originally posted by contourfreak22: Originally posted by loggerbomb: TIP OF THE DAY: get a haines manual, they are handy!
ford shop manual is better, it literally tells you how to take the car completely apart and test everything along the way
as for the tank, you can try running water through it or some sort of cleaner, otherwise there isn't much that you can do
as for a shop, I have no idea, maybe $30 to $50 depending
Posts: 2,483 |
If you want to do a real full system flush, you need to back flush into the heater core.
Do a serach for "flush tee install" there have been 2-3 discussions about a full system back flush.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 1,231 |
the reservoir tank is held on by a couple screws. take em out and take it out. You could try flushing it out with some bleach. let it sit than flush it out.
95 Merc Stique
Zetec 2.0 Auto
CEG road warrior
CEG road warrior
Posts: 17,248 |
Have mine flushed....along with the trans fluid. Don't even want to attempt to flush it myself....just lazy!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
