Page 2 of 2 1 2
Thanks guys,
I guess I was just being skeptical since I got it so cheap.
I may see about smoothing it out a bit. I think it would make me feel a little better.
I know I'm probably being picky (I usually am) laugh
Really I haven't ever seen one and wouldn't really know if I was getting the real SHOypipe so I guess I was making sure of that as well wink
Thanks for the help
Keep posting your opinions or thoughts
Later
FYI:Its Stainless Steel.
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
Yes any of those lips and imperfections will hurt power...
Yes that's the build quality from SHOShop in a nutshell...
2000 SVT #674 - Check it out!
So Demon what would you suggest I do about them?
Exhaust shop, or a dremmel...etc Some of them are hard to reach, would a Exhaust shop have better tools to smooth it out?
Justin
1998 Black SVT
An exhaust shop just isn't going to have the tools to clean those welds on the inside up. If you ask them they'll look at you like your nuts or something. If you want it done then you'll have to do it yourself. Just be careful about taking to much of the weld off with a dremel. If its welded inside and outside then taking off the inside won't hurt a thing. But if its inside welded only, then you'll have to be careful not to remove to much weld or you'll weaken the joint. I can't see those guys just welding only the inside so you shouldn't have any problems cleaning it up your self. Just do it.
Regards,
Dave
In my opinion just clean up some of the weld and you'll be just fine.
Sho-Shop never did the best jobs.
I believe seeing shorter bends like that so I wouldnt worry. (nothing a exhaust shop cant solve)
The U clamps suck though... i ditched mine and bought some band clamps from JC Whitney (On-line)
I did have a wrong size clamp behind the cat and ended up welding it in though.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
Justin, congrats! Good buy, good price! I'd suggest just trying to file those things down yourself, as an exhaust shop probably could give a crap less. So, you're probably going to do a better job. Good luck, and I hope you enjoy it! smile
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
Take a die grinder or dremel and clean up the insides as best as possible.
You will want this to be welded together. The clamps will leak.
Don't forget to to this!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Page 2 of 2 1 2
