Page 5 of 5 1 2 3 4 5
#1150736 01/18/05 03:00 AM
9
Yes the SPEC kit is awesome!!!! Do a search like I said good reviews by people on this board.
http://www.specclutch.com/specMain.html
Thats the link to spec.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1150737 01/18/05 03:11 AM
Arsenal Offline OP
Thanks for the link, looks like the one I am going to go for.
$329 isn't bad, just see on the shipping this kit includes everything right?
#1150738 01/24/05 05:09 AM
Arsenal Offline OP
Well despite the troubles with getting the clutch, the shop is letting me take the car down Monday morning for it to be done. Said they need it for 2 days which is fine.
So hopefully all will go well.
Spec 1 clutch, resufaced flywheel and Chysler ATF4 Fluid
All for $999 installed!
#1150739 01/26/05 10:51 PM
Arsenal Offline OP
Picking the car up around 1:30 tomorrow so fingers crossed!
Was at the shop to drop the new setup off, looked at the old clutch, 2 of the 4 springs were loose, and had chips in them, the diaphram was worn down about 1.5cm and the disc was pretty beat, it was the origional clutch with 86k so lasted a while!
#1150740 01/27/05 09:15 PM
Arsenal Offline OP
Well got the car back today, seems to go into gears fine now, little notchy but just breaking the clutch in. The flywheel was re-surfaced as no warranty with out it. The grabing point seems to be very high though, not sure if there is an adjustment for these cars? Only annoying things is they didn't mark the splins for the steering rack so the steering wheel sits wonky now.
Overall goes into 1st and Reverse fine now! The break in is going to be hard though!
#1150741 01/27/05 09:21 PM
In the SVT (have never driven SE or whatever) you literally only have to push the pedal in 1/2 or so.
Ryan Trollin!
#1150742 01/28/05 12:42 AM
9
They aren't splines its probably hooked up 180 off or so. look at the steering column near the floor. You will see.
#1150743 02/04/05 01:49 AM
Any update on the repairs? How's the shifting?
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#1150744 02/04/05 08:43 PM
arg... after reading this thread... I now have similar shifting problems. Sometimes really hard to put in reverse and 1st, etc... I noticed I have about 3/4" to 1" of up/down play in my shifter too....
morbid 2000 Contour SVT (black)
#1150745 02/04/05 10:19 PM
I had this problem also and plastic bushing was cracked in the gearbox..
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese! diamond pistons for 3.0/forsale #702 of 2150
