Posts: 372 |
I am looking to free up the breathing of my engine to gain as much HP and plan on using a larger TB and MAF to go with my Monster Flow and BAT pipe on the front end, but am uncertain about the exhaust If you were to make a single modification to your exhaust system, $ no object, which would it be. I have an SVT with the resonator replaced by a 2.5" straight thru .. Which of the following do you guys recommend and why? High Flow Cat Cat back exhaust Headers ( Problematic, I live in Ca. with SMOG II) Mufflers other??? thanks jj
Posts: 2,481 |
I would say MSD headers. They come with headers and Y-pipe for $600.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 7,329 |
If you don't care about price
Buy a Bassani or Brullen SS exhaust
The cheap mod
Mystery Mod - no you won't pass with headers!
Posts: 1,701 |
I agree with Icey Mike, but given your smog testing situation you may need to just get a Y-pipe and retain the pre-cats. If you're interested in HP, a clean y-pipe will provide a nice benefit. The SHO design uses a dual inlet main cat which flows a little better than the stock cat. You've already eliminated the other big restriction by taking out the resonator.
Posts: 1,812 |
Money no object, SMOG issues: I say clean up your stock ypipe and get a Brullen exhaust.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 372 |
Gentlemen: Thanks for the input .. pretty much same results I expected. As far as headers go, CARB says there is a "Manufacturers Catalog of approved Parts" out there somewhere, but spent 6 hours on the net searching CARB and ARB web sites and found nothing .. the implication was that there are approved parts for the 'Tour in CA, just can't find a listing .. ? thanks again jj
Posts: 583 |
BRULLEN Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 372 |
Eric: Where are you going to be in Mid July? I will be in Ft Meyers for the AAU 18 and under Baseball World Series .. Modesto Spikes .. we've gone the last 2 years ( in Orlando) this year down in your end of the state. Maybe I'll see you and you can let me know what's hot and what'snot jj
Posts: 653 |
The MSDS hedders should pass emissions, right? Since it has the pre cat bypass thingy that basically fools the computer, or am I wrong. Do emissions places check for precats? Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 5,296 |
Can you put the exhaust manifold heat shield back on and try to fool the emmission people?
