Page 4 of 5 1 2 3 4 5
#1150726 01/17/05 04:54 PM
At least change out the diff, you'll kick yourself later as the labr to do that will be the same as now.
#1150727 01/17/05 05:06 PM
Arsenal Offline OP
I know, its just a lot of money to spend at once. Around $1400 for the clucth, then $600 for the LSD, then another two hours extra to put it in, all of a sudden I am at, $2200. Then the shifter forks aswell, $100, the bushings ect, and its now $2400.
I can't afford that right now, and from what i ahve heard, the diff usually only goes out from a lot of hard starts/launches, which I never do anyways.
As far as clucthes......
#1150728 01/17/05 05:15 PM
$1400 to replace a clutch. Damn, talk about an arse raping. Too bad you aren't in MI. I'd replace you clutch for $650, including the clutch itself.
Also you'd be able to get a Quaife and whatnot done at Terry Haine's in Rockford (Grand Rapids) for a damn good price too.
#1150729 01/17/05 05:21 PM
Arsenal Offline OP
Is that at a dealer? For that price?
#1150730 01/17/05 05:26 PM
No..Stazi is an engineer with ton's O experience with the contour platform. He's a good guy to go to...and that price he quoted you is EXCELLENT...the clutch will run you ~$300 alone...
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
#1150731 01/17/05 05:55 PM
9
Yeah $500 for a factory clutch is too much. Get a SPEC clutch, about $300 for a stage 1 and it has lots of good reviews on this site.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1150732 01/17/05 05:57 PM
If you don't want anything fancy, this is a good deal:
http://www.coximport.com/store/DK-07137
#1150733 01/17/05 08:34 PM
I can get the Sachs from BAT for $390? How are they ect.
The stock clutch is a Sachs. It's a good unit. I'd get a Spec Stage 1 though if I had to replace one.
#1150734 01/18/05 12:47 AM
Arsenal Offline OP
For the Coximport one, has anyone tried it? Not a bad price at all.
The Spec stage 1, does anyone have a contact number and opinions?
Recommended to a shop by BAT, quoted $600 plus tax to do it all, including resurface flywheel.
I am still not sure its the clutch though, there is no clutch slip at all.
#1150735 01/18/05 02:33 AM
It may be the slave cylinder not working very well any more - it's common for those to wear out and when they do it makes shifting a PITA. Once again, the only way to change this is to pull the tranny. Either way if you swap out the clutch you should swap out the slow cylinder.
