Page 2 of 2 1 2
#115002 03/06/02 09:16 PM
Let me also say that the stock cat has a nice 3" opening ( perfect match for 3" collector on MSDS Y or if you modify your stock Y). The inside looks virtually the same as a Catco 3" which I bout but decide not to install as it looked the same when I had it all apart. Unless you are going to a trick metal matric cat or something I dont think any ceramic brick aftermarket cats are likly to be better than stock. Probably is a gain going to straight pipe (but not gutting cat).
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#115003 03/06/02 09:44 PM
Originally posted by Big Jim:
I had understood that the SVT had different cats that flowed better, but now I'm not so sure. When my CEL was acting up from a code that showed that the rear car was below threshold effeciency, I priced a replacement. To my surprise, it had the same part number as the non SVT. My cat started working properly again, so I did not follow up on this to confirm that the part number was the same.
BTW, i just had my cat replaced free under emissions waranty 8/80
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
#115004 03/07/02 12:19 AM
DaveNC Offline OP
Thanks,
You guys confirmed what I thought. It will be very easy to get rid of the 2" restriction from the cat to the flange. I looked again tonight when I got home from work and there is at least 1" of 2.25 inch pipe coming out of the cat before it gets necked down to 2". I can weld the new 2.25 pipe and flange up this weekend. I might even fix the y pipe and do the Mystery Mod as well since I'm going to be under the car anyway.
Dave
Page 2 of 2 1 2
