Page 2 of 2 1 2
#114963 03/06/02 09:26 PM
Thanks again all,
Demon do you know which 4.6 kit your's is from? BBK & March (& others I think) make 3 pulley kits for around $120. If the 4.6 kit's alt and P/S pulleys both work it may be worthwhile (and just pitch or sell the crank pulley).
In general are 4.6 alt & P/s same as Duratec??
David, how much was the ASP?
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#114964 03/06/02 09:28 PM
It was 100 bux
David Zambrano
svt_mondeo at yahoo dot com
CSVT E1 #4808 - soon to be 400hp
You get what you pay for. All advice here is free.
http://www.geocities.com/svt_mondeo- my homepage
#114965 03/06/02 09:53 PM
I think it was the BBK kit. I never asked honestly. (his headers and TB are BBK, so it's an educated guess - I can ask him next time he's home from college) However it really shouldn't matter. They both fit the same application right...
Without seeing the 4.6 P/S pulley I couldn't tell you, but I can take a pic of the stock Duratec P/S pulley (4 hole mount with center alinment dowel) and post it so you can print out something to match it up with...
If the 4.6L will work; at $120 that's a steal.. laugh
2000 SVT #674 - Check it out!
#114966 03/06/02 10:01 PM
I just checked out all the UDP pulleys for the 4.6L and no where do any of them list a P/S pulley.
Crank, Alternator, & Waterpump...
#114967 03/07/02 11:28 PM
David, what % underdrive is your ASP pulley? Do you also have a crank pulley? Any effects noticed on steering? I may give them a call.
Demon, yep - your right all the 3 pulley 4.6 sets I can find are crank, alt, wp. Nuts...
#114968 03/08/02 01:26 AM
To make sure the pulley would fit I had them increase overall diameter by 10MM. That still leaves about a 5-7mm space from the pulley to a bracket that over hangs the pulley. It should have enought room to actually increase the diamete by another 10MM.
I'm using a stock crank pulley and there is no noticeable effects on the steering.
David Zambrano
Page 2 of 2 1 2
