#114913 03/04/02 01:34 AM
guys, from what i can tell the egr valve on the 2.5L is vacume actuated correct?
There was an old mod in one of my toyota performance books many many years ago that involved placing a bb, yes a bb like form a bb gun, in the vacume line that pluggen into the egr valve (it was a tight fit so no worries about it getting sucked up anywhere). This prevented the valve from opening but was easy enough to reverse.
Any thoughts on this? Think it would trigger a CEL?
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
#114914 03/04/02 01:51 AM
9
9
Would it really be worth it? I dont see how much performance gains you would get, and the engine is designed to have it on, so.... -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#114915 03/04/02 01:52 AM
Yes, it would trigger a check engine light.
You can, however, install a restrictor plate between the EGR and the Intake Manifold with a smaller diameter hole to restrict the EGR flow.
I have this installed, and many people feel it helps with initial throttle response.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
#114916 03/04/02 03:20 AM
For what it's worth, it is illegal to tamper with emissions control devices. If a dealer or emissions check location sees that you're in big trouble.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#114917 03/04/02 03:37 AM
1
1
So is a turn in front of a mini van!
#114918 03/04/02 03:39 AM
Oh well **** Tim, I just meant to do it. :rolleyes:
AND YES THAT IS A JOKE FOR THOSE OF YOU WHO DIDN'T GET IT LAST TIME.
Dan Parmelee
#114919 03/04/02 06:45 AM
This mod does seem to provide a little more pep. My restrictor plate is the same size as the EGR gasket but with a 5/16" hole. Blocking up the EGR completely triggered a CEL on my OBD-I vehicle.
Scott
#114920 03/04/02 06:53 AM
I can buy maybe seeing some better tip in throttle response (makes sense), but it will not generate power gains since the EGR is not used above certain throttle percentages.
2000 SVT #674 - Check it out!
#114921 03/04/02 12:09 PM
More chance of det with no egr FWIW...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#114922 03/04/02 12:18 PM
Thanx for the responses guys. I was more interested in throttle response and keeping the intake track clean then anything else. I guess i'm either leave it alone or try the restictor plate idea.
Just bored and waiting on parts to show up.
98 SE
====OnOrder====
