Page 3 of 4 1 2 3 4
#1149029 01/09/05 06:06 PM
hi Arsenal and welcome..... my old lights did that (flicker) on my mondeo i dont know if it will be the same folt but i had a clip broke in light unit, the clip was holding the silver refelctor i'd look at that very poss a quick fix
#1149030 01/09/05 10:34 PM
A/C kicking on will cause a noticeable jump, anyway... not a problem..
Ray
#1149031 01/09/05 11:21 PM
Arsenal Offline OP
thanks, looked at the compressor today, clutch seemed to be kicking in okay. Now down to the shifting!
Where abouts are you from in England? Use to live in Swindon, but family all over, live in FL now.
#1149032 01/09/05 11:30 PM
i live in Taunton near bristol
#1149033 01/10/05 07:46 AM
do they flicker when u first start the car up , like flicker in and out a couple of times and then it goes to normal , if so thats a new feature that they put in contours and svts , what its does is it surges the power in and out a couple of times , so it prevents the wiring from being fried
#1149034 01/10/05 05:54 PM
Step away... from the crack pipe.... slowly...
Ray
#1149035 01/10/05 06:02 PM
That is the BIGGEST LOAD I've ever seen posted on these boards. Where did you get THAT information??? (I'm guessing a used car salesman or a "friend".
#1149036 01/10/05 07:15 PM
Arsenal Offline OP
Actually it does do that. Also took a closer look and found out that a couple of tabs were broken so causing it do more than just flicker.
Any one have a problem with the key tumbler, as if it is hard to get the key into?
#1149037 01/10/05 07:27 PM
As for the key tumbler, try turning the steering wheel a little bit in either direction. Happens to me ocassionally.
#1149038 01/12/05 03:27 PM
Z
Z
congratulations on your purchase and welcome to the world of being a csvt owner...."it is a great car but the little quirks will drive you insane!!"
2000 csvt #1553 Black/Tan
Page 3 of 4 1 2 3 4
