Posts: 4,693 |
Originally posted by DanburySE: there is a orange tab inside the trunk. right below the latch itself. this tab controls "valet mode". valet mode makes the keyless entry and the interior trunk opener inoperative.
I just checked my car. When the disabling lever is switched on the trunk latch in my car, the trunk still opens with the key fob, but not from the release lever by the driver's seat.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,693 |
Originally posted by CSVT985: I replaced the stock keyless entry with an UNGO alarm system.
That may explain part of the difference.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 759 |
Originally posted by Big Jim: Originally posted by CSVT985: I replaced the stock keyless entry with an UNGO alarm system.
It didnt work from the beginning though, but I am almost certain there has to be a solenoid to power the trunk release. I cannot find one in my CSVT. Is in the glove box?
I would like to find it so I can rig up a manual release button and then add it to my transmitter.
E0 #4384 of 6535
Born Jan. 9 1998
My SVT from the ashes
147,466 miles, purchased Nov. 2002 @ 76,559 miles
Posts: 392 |
I do have the remote trunk opener. When i use the remote i can hear the solenoid to release the trunk. But when you use the latch on the driver side of the seat you don't hear any sounds, and it still unlock the trunk.
So it's probably electric for the remote opening and mechanical for the latch.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 4,693 |
Originally posted by CSVT985: Originally posted by Big Jim: Originally posted by CSVT985: I replaced the stock keyless entry with an UNGO alarm system.
The release solonoid or motor is in the trunk lid near the trunk latch.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 759 |
I apologize, I was wrong I got my old fob out (ironically it still panics, locks and unlocks) It made the clicking noise from under neath the glove box whenever I hit the trunk release after I switch the trunk switch from mechanical to button release.
Now heres the problem, do I have to replace my solenoid or motor or what? I am going to go see if I can remove the motor and clean it up or something Thanks again.
E0 #4384 of 6535
Born Jan. 9 1998
Posts: 4,693 |
I would guess that the release solonoid isn't working. Start by making sure that you are getting power to it when you push the button on the key fob. If you have power to it and it has proper ground but doesn't work you will need to replace the solonoid. If you don't have power to it, you will need to trace back to the relay and find where the power was lost.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 759 |
I took my voltage meter out there and am getting full power to the solenoid. It is bad. So should I try to get one out of a junk yard. I went to Ft. Worth and they just delivered a 98 Red SE there (I got a headlight and front grill chrome ring for $25.00 barely used) and I am sure it has a solenoid in the trunk. Or get a new one from Ford for ??? dollars?
Thanks
E0 #4384 of 6535
Born Jan. 9 1998
Posts: 319 |
if the solenoid is also called the actuator i foud it online for $18 and change. might be better to buy new at that price
'98.5 Black Ford Contour SE Sport 5-speed. All the SE Sport features with all the 98features that were supposed to be decontented for 98.5
'04 Silver Toyota RAV4 L Auto. Fully loaded.
