Posts: 456 |
I to am checking out the Cheap-TSW Monza 16x7.5 -35mm wheels on Ebay... Will it work and what tire size? I think it will work OK and with 215/45 or 50 16s, my car is not lowered now... ![](/ubbthreads/images/graemlins/wink.gif) Yes I Searched! (not much on 16" wheels) It's the -35mm offset I'm not sure of and the width. Better than steeles and 14s, and kinda "Supertouring" !!!
01 PORSCHE 996 ![](/ubbthreads/images/graemlins/smile.gif)
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
96 GL MTX Zetec 2.0 ![](/ubbthreads/images/graemlins/smile.gif)
White/Blue
Blaupunkdt Houston
K & N Drop in/Koni Kit
18"RageEnduros/Flowmaster 40 Series
Posts: 456 |
My mistake its a +35mm offset (same question)......... Please Help!
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
White/Blue
Blaupunkdt Houston
Posts: 2,676 |
I don't know, that's going to stick out A LOT. Remember stock offset is 49mm, and that's tucked away under the wheel arches. The lower your offset, the more it'll stick out (if I remember correctly, someone could correct me here. . .)
Suneil
Posts: 2,728 |
'03 SRT-4
50 trim turbo + support
Posts: 9,602 |
Originally posted by RyeLou: Isn't stock offset 40?
Stock offset is 49.5mm
So 35mm is ~2/3" less. Thus meaning those rims would likely rub on the struts. They definitely would not clear the brakes though.
Stock 16x6.5 +49.5mm rims are well within an inch of the struts with tires on them. With 225/50's they are mighty close! 245/45's require 10mm spacers, fender rolling, and still nearly touch the struts!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,867 |
Originally posted by DemonSVT: Originally posted by RyeLou: Isn't stock offset 40?
Positive offset is toward the center of the car, right?
My 16x7.5 rims have a 43mm offset. Most of the popular 16x7 rims have 40mm. I've run 205's, but nothing wider, so I'm not sure if that would work.
Might rub on the fender lip... Might be fixed by rolling the lip, or might not.
Function before fashion.
'96 Contour SE
Posts: 1,036 |
Originally posted by RogerB: Originally posted by DemonSVT: Originally posted by RyeLou: Isn't stock offset 40?
Yes, positive offset will be towards the center. So the 35mm offset will give a wider track, so the wheels will probably rub the fender lips, since my 18x8 with 40mm rub a little. What's the bolt pattern?
dion
98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
Posts: 3,496 |
Why not upgrade to a Focus Wheel and Tire Package, they are "SuperTouring" enough?
Learned patience the hard way
Posts: 2,454 |
35mm will get the wheel close to the outer fender, but since you aren't lowered it might not rub. With them being that wide, it might be a bit tough to find a good fitting tire for that rim.
Demon, the 245's fit with fender rolling and a 5mm spacer on a 42mm offset rim (SSR GT1 16").
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 3,867 |
Originally posted by Buckshot77: With them being that wide, it might be a bit tough to find a good fitting tire for that rim.
Rick
205/55-16 is a very common size... 225/50 a bit less so.
'96 Contour SE
