Posts: 4,141 |
this is what happens when you keep your mouth shut about an item you find on ebay aussie bar: $41
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,238 |
Sweet deal! I wonder if Stazi will ever make another batch?  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 9,602 |
Originally posted by tropictour: Sweet deal! I wonder if Stazi will ever make another batch?  -tropictour
No.
From what I remember his place of work nixed the idea of any more units thus making the few units produced quite rare comparably.
Glad I have one from the first batch.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,506 |
Remember to box up or reinforce your rear subframe when you put that puppy in, so it does not just break the mounts loose when you play with it.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 1,130 |
We would have had a bid war had I decided to buy that item! I almost bought that same bar, but I am happy with my bat bar and dont want to deal with reinforcing anything.
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 9,602 |
Originally posted by RandyCSVT: but I am happy with my bat bar and dont want to deal with reinforcing anything.
Even a stock bar (19mm) with poly bushings has torn out the mounts.
Also the stock mounts are so weak they bend with the stock bar.
ANY setup should have them re-enforced. You are not getting the real benefit of your rear bar when the mounts bend. Especially a larger bar.
Also any time the mounts bend you get erratic rear handling. Very bad!
So do not think you are "safe" just because you do not have an Aussie bar! 'nuff said.
2000 SVT #674
Posts: 217 |
Yeah, what Demon said.
George Hodge
New: Volvo S60R
Old:2000 SVT Silver Frost 1188/2150
DMD, 75mm Pro-M, HPP rear strut tower bar
Aussie 24mm sway bar (with boxed in subframe)
BAT European Handling Kit, Brullen Y-pipe
Performance Ford spherical bearing end links
Posts: 225 |
Originally posted by DemonSVT: Even a stock bar (19mm) with poly bushings has torn out the mounts.
Also the stock mounts are so weak they bend with the stock bar. ANY setup should have them re-enforced. You are not getting the real benefit of your rear bar when the mounts bend. Especially a larger bar. Also any time the mounts bend you get erratic rear handling. Very bad!
I�m sure glad to hear about this now instead of after I�ve installed my rear bar. Do you have pictures of what the reinforcing should look like?
The Original Owner of 1998 SVT Contour #3384 of 6535,
Toreador Red/Midnight Blue, Assembled September 3rd, 1997
Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed,
Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
Posts: 9,602 |
Originally posted by NVSVT: I�m sure glad to hear about this now instead of after I�ve installed my rear bar. Do you have pictures of what the reinforcing should look like?
It's Not our fault people can't search.
Seriously though. This information has been well known and posted for years now.
There is even at least 1 if not 2 how-tos with pictures on how to box in the subframe. I know one of them has excellent pictures.
It's all there if you look and read.
2000 SVT #674
Posts: 1,130 |
I searched and found very little about boxing in the subframe. I got one post with expired pictures. Somebody help me out. I guess I am not so good with this search function. Before anybody gets mad I would like to say that I searched both the current forums and archives for about 1/2hr.
Once you box it in are the brackets permanently in place? I would like to be able to grease things up or even change sway bars later without rewelding things.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
