Posts: 89 |
So with the stock svt exhaust, if you replace the resonator with a magnaflow does that sound more raspy than a glasspack or is just removing the resonator and putting just tubing in its place sound better?
Posts: 288 |
take it from me. go and spend the money on a trubendz setup for like $300 plus shipping . i tryed to take the easy way out myself like you but it only leads to the honda sound.
well my exhaust doesn't sound like a honda it does have an import sound though. no rasp but still crappy, its louds just doesn't sound like it has any balls.like it did before i replaced the stock resonator.
remove the stock mufflers and or replace them with high flow units.would be the cheap way out with a decent sound.
if you replace the resonator with a high flow straight through design you won't get the sound your looking for i've got a magnaflow 2 1/4 " inlet and outlet straight through design with a 2 1/2 " core ,4" round muffler sounds crappy in my opinion.
save your self the money in the long run and buy a cat back.
if you replace the resonator with a straight pipe you will hate it. i have a magnaflow and still hate it.
-2000 csvt silver frost #1619
-magnaflow 14415
-optimized T/B & y-pipe
-superchips xgt1
-75mm proflow maf
-K&N RU-3530
-fsvt smart pump # 354Z-9H307-BC
-spec stage one, LSD
-low-tek,a/f,oil press.,volts
-B&M short shifter
-17" konig gt-r
Posts: 10,015 |
Order of raspiness:
1)Straight Pipe (lots of rasp) 2)Glass pack (a little rasp at first, then as the stuffing blows out it gets obnoxious) 3)Magnaflow (not raspy ever)
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 115 |
Yeah, just go with the Trubendz setup. Take it from me. I wasted $250+ on a crappy Flowmaster muffler and labor, when I could have had an entire catback system installed for $310 with more power and a better sound to boot. Hail Trubendz.
'98 Contour SE 2.5 w/ Granny Tranny + stuff = still slow
Posts: 53 |
Whats wrong with no resonator and a quasi dual hi flow magnaflows Sounds great just not too loud. A hiflow y pipe should give me the sound i want. If you want a real muscle sound by a muscle car.
Posts: 68 |
98 SVTour / 86 5.0 Capri
Posts: 9,872 |
bassani is raspy as hell..IMHO
Posts: 68 |
Okay, I am going to order this from Trubendz.
FORD CONTOUR SVT DUAL EXHAUST (fits non-SVT with adjustments) ALUMINIZED STEEL 2.5 INCH WITH MAGNAFLOW MUFFLER AND SS TIPS. PRICE: $310.00 SHIPPING: $30.00
Hopefully I will end up with a decent sound, NO rasp, and not be deaf by the time it comes in the mail.
Next week professors I need to know more about the "moose" and what the heck is causing my car to studder. Then I can move on to improving the performance more instead of fixing what's broken.
Posts: 759 |
Any reason to go with Alumized over Stainless besides lower price? What are the benefits of the stainless version?
Posts: 9,602 |
Originally posted by mamisano: Any reason to go with Alumized over Stainless besides lower price? What are the benefits of the stainless version?
Cheaper & lighter (significantly & minorly)
Lasts close to twice as long (guesstimating 8-9 verses 4-5)
2000 SVT #674
13.47 @ 102 - All Motor!
