Page 2 of 2 1 2
#1144521 01/05/05 04:29 AM
1.Can you replace EVERY bulb in the gauges with the #74 type leds?
2.how would that look because i plan to do green?
3. i take it you need the 74 bulbs WITHOUT the base?
4. Which bulbs are for the speedo/tach neddles?
~Alex
can anyone shed some light?
1. Yes, except one. which is already an LED. can't remember whihc one. It will need a 5mm led soddered in. #74 bulbs are expensive and worthless imo.
2. Since you have a RED needles, you will need to replace them with clear ones. which can be a fun process since you need to recalibrate your speedo. or do it perfectly. Doing leds in your gauges, i suggest only doing white. unless you have indiglo and clear needles/white needles.
3.Yes buy without the bases.
4. there are 5 bulbs.
(non-svt gauge pod, svt is very similiar, bulbs located in the same spots.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
#1144522 01/05/05 02:01 PM
Are there any specific leds simply for the needles, with those i will put red or white leds to make it really bright. I'll pass on replacing the needles and having to be recaliberated because i know i can't do it perfectly.
~Alex
#1144523 01/05/05 05:03 PM
the ones marked with yellow are the back light and needles.
#1144524 01/19/05 01:48 AM
Think if I put BRIGHT YELLOW LEDs itll turn blueish with the green already in there? You know....both colors mixes a blue color.
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
#1144525 01/30/05 07:11 AM
you got urself all backwards, yellow and green dont make blue, its blue/yellow = green
FORMER OWNER 2000 Black SVT #934 of 2150
Page 2 of 2 1 2
