N
N
Does anyone know where I can get a a Vortec S/C installed in the Mississauga or Toronto area and how much it would cost?
I'm looking to get my S/C installed shortly since the SVT is off the road for the winter.
Thanks!
2002 BMW M5 Carbon Black on Black 1998 Frost Silver SVT E0 17" Masitaly rims with Bridgestone Fuzion ZRi rubber. 133,000km 1996 Silver Ford Taurus SHO ATX 180,000km - SOLD! 1996 Midnight Red SE MTX 295,000km and a little squeeky.
Too bad Chris doesn't have his own shop From what I understand, the install was a bit tricky but doable.
The only real performance shops I know of are:
- Steeda.ca/Mustang Performance Warehouse in Milton
- DaSilva Racing in Scarborough
- TAG Motorsports in Oakville
DaSilva is probably booked solid from all its Mustang clients. Steeda/MPW just opened their place not too long ago.
Avoid any place that has been on Tuner Transformation or the likes. Steve from the Focus commercials had a bad run-in...I'm still not certain they fixed his Vortech on his ZX5.
Richard | Focused 24-7 2002 Focus ZTS...+275,000km and beyond! Ontario Focus Owners Club | SVTOA-Toronto | SVTOA Redline Rendezvous
Just contact Chris from CTA Motorsports. Since yor in Mississauga you aren't to far from Chris either.
Aaron
All I can say is, welcome to the SC club. It would be recommended to have a place with a hoist, and I will tell you from personal experience, removing the subframe makes the job a heck of a lot easier, but......., it doesn't have to be removed. Saying that, expect to take at least 3 days or longer, of constant work to get it installed, not the 14 hours (BS) that Vortech claimed. I can see 14 hours, when the engine is sitting on an engine stand, and the engine is not equipped with A/C lines.
N
N
Hi Chris,
What were some of the issues that you ran into during your install?
Also, how many k's have you put on the car since the install? (How is the S/C holding up?)
Originally posted by Nate Payeur:
Hi Chris,
Maybe 1000Km if your lucky. Chris' car is not a daily driver so for normal wear and tear related issues you will have to ask in the FI forum. From what I understand the jack-shaft is the biggest issue. IIRC there is an upgrade for it or someone machined a piece to make it run true. Good luck with the install, let us know where you're doing it so we can pop our heads in.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
Actually, I have about 4000 kms on the superhcarger now. I did a lot of driving the first year with it, not so much last year.
Issues, fitment issues mainly. Everything is tight, and some of the parts did not line up, requiring modification, including the discharge volute pipe which had to be cut. The supercharger exit volute was not set at the right angle. I have since corrected that when I installed the after cooler.
Oops my mistake but still not what you would consider a daily driver .
Moderated by  Gerald_dup1, mbb41_dup1
