Posts: 94 |
I have no chip, it is the stock v-6
99 Tour SE Sport 24V Cabernet Red Xplod Head unit/Xplod 760W Amp/15" Rockford HE2 2 10" blue neon lights in footwells Moonroof, Spoiler, Re-wired fogs to work right, 50w Xenon Fogs 80w Hyperwhite low's from midnightmoose
Posts: 74 |
Well, I Guess you could be right about the speedometer being off. Yes, I know the Zetec sounds bad @$$ at high revs. Too bad it doesn't do much for acceleration. My car seems to be better in the lower end. Need less to say. Without a cop or a radar gun, I could never verify that. :rolleyes:
1995 Contour GL Zetec 5spd Airbox removed w/ cone filter added. Tinted windows, VentShades. FUTURE: RIMS!, Power W/L/S, Aiwa CD PLayer, Pioneer Speakers, CTA Intake, Custom Cat-back, SVT BK, WW Touring Spoiler, H&R springs, and graphics by PRO-STYLE Graphics of Orange City.
Posts: 4,899 |
In the 95s, if you disable the VSS (vehicle speed sensor), you also lose cruise control, but the governor disappears! Car has no idea how fast you're going. Thank god for cable-driven speedos! BTW, this will not work on 96+ cars.
Posts: 3,934 |
Originally posted by contour1995: Are you sure about that? I read on one of the websites (not sure where now) that it was 143 for all contours! Let me know. The 143 drag speed would be for a stock SVT. If you increased its power the car would go faster. That is why a Zetec tops out slower, less power.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 7,329 |
Originally posted by mbb41:
If 130-135 is accurate then how is this tripping the meter? he does have a 24v. BECAUSE there is a limiter in the PCM to 112mph for all Non-SVT's. psst... read the other posts...
Posts: 803 |
psst... read the other posts... Sorry I wasn't clicking and I did read all the post. I was just more curious how it was bs if the car was powerfull enough to do it sans the being chipped factor....my bad! :p
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 716 |
Originally posted by Gregg C.: i've heard that speedo's are 5- 10 mph off when you get that high..i know i've had mine to 120 moh on the speedo and felt like i could go faster..would love to try..the zetec sounds sooo nice when its revving that high... Well I know mine is off at that speed. I timed myself on the interstate once. Doing an indicated 110mph, I clocked 30 seconds between two mile markers, which equates 120mph. and I KNOW it has more in it than that, as it will hit the rev limiter HARD when accelerating, I wouldn't be surprised if she could reach 135, maybe even 140 with a real superchip -Chris
Chris Hinds AIM:CJ111010 1998 Contour GL Duratec 5-Spd #565/???? 15.610 @ 89.62mph And I payed for it all myself
Posts: 803 |
Someone should just chart up a speed per rpm chart in final gear. That way when you know what your indicated rpm is you can correlate it to your speed :p I'm pretty sure that redline is around 140 to 150 mph or 240.5 kmh. Just a thought that could save all the questioning :rolleyes:
Posts: 7,329 |
Originally posted by mbb41: Someone should just chart up a speed per rpm chart in final gear. It's been hashed to death already many times. This topic comes up every couple months or so. People always believe thier speedometer over physics and gear ratios for some odd reason... :rolleyes:
