Posts: 7,329 |
Originally posted by jcboeckl: I don't think Demon cut his accordian but rather cut his BAT intake pipe to make it fit, unless he has done something different since then?
Yes. I cut almost 1" off my BAT pipe. Still a very tight fit. I'll likely trim it a litle more next time I take that area apart.
Posts: 1,812 |
Hmmm...don't know if I want to cut anything just yet. Still under extended warranty, and it'd be a PITA to try and hide a cut accordian... DANG! Good prices temp me!
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 667 |
Derk you might want to check with your dealership, but I highly doubt cutting the accordian will void your warranty, at least I know it wouldn't with my dealership!
Posts: 2,066 |
I think headers would more likely void your warranty than that.
Posts: 1,812 |
Originally posted by jcboeckl: I think headers would more likely void your warranty than that. True, Justin, but it's all about being able to make it look as stock as possible when I need to. Who knows. I'm debating.
Posts: 667 |
That's as stock as it's gonna get compared to actually putting on a BAT Inlet Pipe.
Posts: 2,906 |
I already have adapter with K&N but the filter is pretty much destroyed. From the post, I gather that the filter you are selling will not be a direct bolt on because the accordian tube will have to be cut to fit this new filter?
Do you sell K&N filters like the ones above? Or one that will fit without modifictaion to tube? I have Mirko adapter (similar to KKM adapter but much nicer).
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 308 |
Does anyone have any pics of how this looks inside the engine?
99 SVT Green/Tan #44 TH-Fix, Aussie Pipe, PRO-M, SHO-Shop Y, Borla, and other Misc. 93 Tracer LTS Eibach, K&N, Misc (now my winter beater) email me: keith@thinkingcapdesign.com My Car: http://www.thinkingcapdesign.com/KeithsSVT/
Posts: 3,248 |
"Hmmm...don't know if I want to cut anything just yet. Still under extended warranty, and it'd be a PITA to try and hide a cut accordian... DANG! Good prices temp me!"
Derek, check around, people always selling intake parts. I bought a used one cheap - to have in case I screwed the one I was modifying (fortunatly I did not) and to have for trips to dealer - I have a stock airbox/MAF meter/airtube all assembled that can be installed with a screwdriver in under 2 minutes.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 1,812 |
There's a though, Dan. Thanks!
