Posts: 208 |
Although I may could search and find a answer I am lazy so why does everyone want to replace the resonator with a muffler then replace the rear mufflers? Either cut the resonator and replace the rear mufflers or replace the resonater with a muffler and cut the rear mufflers off.
Posts: 4,476 |
Originally posted by silverbullet: Although I may could search and find a answer I am lazy so why does everyone want to replace the resonator with a muffler then replace the rear mufflers? Either cut the resonator and replace the rear mufflers or replace the resonater with a muffler and cut the rear mufflers off. i'll give it a try the center resonator has been shown to restrict exhaust flow and by removing it - or replacing with a high-flow muffler you can free up anywhere from 1-3 HP (not much, but it's cheap HP) - the rear mufflers aren't very restrictive but lots of folks like to either remove them or replace with a better sounding aftermarket muffler (i.e. Vibrant, Dynomax, Edelbrock, Magnaflow, etc) i'm probably going to do the Edelbrock 5503 and cut the rear mufflers and put some new tips on the back... (probably 3.5")
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 4,476 |
up top - i'm gonna order this for myself (birthday is Tuesday) can anyone beat the $87.95 price???
Posts: 583 |
From the picture, I know you guys aren't going to try to say thats a straight through design right?
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 316 |
Mufflers Edelbrock 5501 and 5503 492 scfm Dynomax Ultraflo 17216 711 scfm
Resonators Edelbrock 5505 708 scfm Dynomax Ultraflo 17218 1000 scfm
The proof is in the numbers. DYNOMAX
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 4,476 |
Originally posted by HoosierContour: Mufflers Edelbrock 5501 and 5503 492 scfm Dynomax Ultraflo 17216 711 scfm
The proof is in the numbers. [b]DYNOMAX[/b] so what is the flow rate on the stock resonator? also - sound is a big different between the two, i've had dynomax before - sounded great on a V8, i'm looking for more of the "ferrari/porsche" sound on the SVT
Posts: 4,476 |
yay - finally got the 5503 in my hands!!! hopefully i'll get it put on tomorrow!
Posts: 4,476 |
ok - so i went the the muffler shop, the guy said i need an offset/offset muffler - he said that the 5503 center/offset will not work - really bummed...
is this guy smoking crack? i have the SHO y-pipe if that helps at all...
doh!
