Page 3 of 3 1 2 3
mangler Offline OP
OK, so what values am I monitoring with the OBDII scanner? First bank o2 sensor? Which one is the o2 sensor before the precats? Is that the one that supposed to give me 0.86V and up? Thats an average, correct?
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
I
I
$14 02S SHRT FT 11
mine likes .88 20 or .90 38
.88 volts or .90 v with 20 or 38 percent trim increase lean correction.
98 Contour LX V6 Mtx
mangler Offline OP
Way to answer the question indy!I'll have to check that sensor on my next drive...
Marco Tatta
Originally posted by Kaiser.:
The dyno I use you can see the air/fuel. When the secondaries open there is a bump in the torque horsepower. There also is a bump in the air fuel being that there is more air rushing in. This is how I gauge the speed. It is about 200rpm off.
I also found out that some sniffers can add air and throw it off an extra 1000 rpms.
If it's true that we are here to help others, then what exactly are the others here for?
Page 3 of 3 1 2 3
