Posts: 245 |
im looking for some nice street tires does anyone have any good ones i should look at and if you know the price that would be great
Posts: 21,653 |
How about you say for what wheel size and what you want outta the tires.  We're not psychics.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 245 |
185 60 r 14 i want good tires for road rallys
Posts: 7,117 |
Originally posted by AquaFBody: 185 60 r 14 i want good tires for road rallys
You might want to go with a wider tread patch; 195-60/14 are what I had on my car.
I presume you use your car as a daily driver too. Go with a good touring tire. Hit tirerack.com and check out the Yokohama AVID TOURING tire. Was a fantastic tire for me & my daughter. Only better tire I could find with the desired characteristics was the Bridgestone Turanza LST - which I just replaced on my car. The Yoks were smoother & quieter, but man the Bridgestone never gave up, always gripped when I needed them most.
Both of those are 70,000 or 80,000 mile tires - excellent value & good all around performance.
Posts: 610 |
BF goodrich Radial T/A 215/60/14...wont be regretted
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 7,117 |
Originally posted by ContourGuy9817: BF goodrich Radial T/A 215/60/14...wont be regretted
That tire is way too large. Speedo will be off big-time. Better if you take the profile down a bit.
205/55-14 should be just about spot-on!
Posts: 21,653 |
Originally posted by TourDeForce: Originally posted by ContourGuy9817: BF goodrich Radial T/A 215/60/14...wont be regretted
Actually 215/60/14 is almost dead on match for speedo. I don't know if that wide of a tire will fit the stock wheels though.
98.5 SVT
Posts: 245 |
im looking at some nakang EX-601's there 185 60 R 14 82H what does the 82H mean
Posts: 3,045 |
Originally posted by AquaFBody: im looking at some nakang EX-601's there 185 60 R 14 82H what does the 82H mean
82 is the load rating and h is the speed rating, see here:
Service Description
The service description consists of two things:
Load Ratings: The load rating is a number that correlates to the maximum rated load for that tire. A higher number indicates that the tire has a higher load capacity. The rating "105," for example, corresponds to a load capacity of 2039 pounds (924.87 kg). A separate note on the tire indicates the load rating at a given inflation pressure.
Speed Rating: The letter that follows the load rating indicates the maximum speed allowable for this tire (as long as the weight is at or below the rated load). For instance, S indicates that the tire can handle speeds up to 112 mph (180.246 kph). See the chart on this page for all the ratings.
site full of details about those pesky numbers on our tires
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 610 |
well those tires are mounted on my car right now? i think they ride pretty nice, they definetely dont rub or anything and they definetely give me the traction i need throughout mother natures little escapades
2002 Cougar
2.5 duratec/ mtx-75
85,0000
black/black
Spec Stage 1
Torsen T-2
apexi s-afc II
K&N FIPK
