just as a heads up, check the water pump on the one you are looking at... Common thing to fail on the duratec contours, the water pump impellar is made from plastic... If it does go you can get a replacement Water pump from NAPA with a metal impeller... Which it is very worth it... Thats about it though, WELCOME To CEG and I hope to see you around.
