Posts: 249 |
yeh maybe thats why i push the gas down as i release the clutch then i get on it so it doesn't spin at all
2000 SE SPORT V6 MTX BLK
MODS:
KKM INTAKE
DUAL EXHAUST/NO RES
BOSCH+4/CHIP
SHORT SHIFTER/INDIAGLO'S HVAC/DASH
MESH GRILL/CLEAR CORNERS/EYELIDS
Posts: 5,600 |
well there is still room for more throttle before you get spin. i can feather the clutch and launch from ~3000 with minimal tire spin.
Black 1998.5 CSVT
Posts: 2 |
Hey folks. I'm completely new to this forum and I have a '95 w/V6 and automatic. And I have a suggestion for this guy's issue. The best way that I've found to launch a 5-spd is to rev to about 4k or so and drop the clutch. So what if the tires fry a little? They'll hookup soon enough. The only problem with the V6 is it's low low-RPM torque. It's a high RPM engine, limited to an impressive 6900RPM. And the only way to perform a decent launch is with the tach above 3500 or so. The Duratec 3.0, however, is much more torquey. By the way, I've fried the tires with my automatic also, just gotta know how to do it.
Posts: 21,653 |
Umm wheel hop, umm bye bye tranny, bye bye tranny mounts.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 192 |
Well actually i've raced my friend and he has an 98 SVT and i have a 98.5 SVT and he doesn't spin his tires, but I spin quite a bit. I tend to get a little jump on the start, but all in all, it's pretty equal... So in my oppinion, it's all whether or not you want to show your racing with a little squeel or not.
1989 Toyota Corolla (Totaled, now father car)
1990 Isuzu Trooper (Sold for more than bought)
1998 Ford Contour SE (Totaled in moutains)
1990 Toyota Supra (Blown head gasket)
1998 Ford Contour SVT (So far so good ::knocks on wood::)
Posts: 7,100 |
Wow.. I know for a fact that SOMEONE will take your advice on a 4k launch and "who cares if you roast the tires, they'll hook up sooner or later"... What about "who cares if you grenade your tranny, or blow the differential?" that's the sad part, too.. that someone will actually listen to what you just advised..  Ray
'99 CSVT - Silver #222/276
Posts: 1,899 |
Originally posted by Ray: Wow.. I know for a fact that SOMEONE will take your advice on a 4k launch and "who cares if you roast the tires, they'll hook up sooner or later"... What about "who cares if you grenade your tranny, or blow the differential?"
Ray
Is it really that easy to fry a tranny is a contour i want something that can take a little wheel hop when i'm trying to learn how to launch it....
Posts: 7,025 |
dropping the clutch at 4K is def. not the way to pull a good 60 foot time.  Seriously, all the guys that pull 2.0 60' times are revving at like 2,000-2500 rpms and slipping the clutch.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,899 |
Originally posted by beyondloadedSE: dropping the clutch at 4K is def. not the way to pull a good 60 foot time. Seriously, all the guys that pull 2.0 60' times are revving at like 2,000-2500 rpms and slipping the clutch.
what would happened if you dummped it at thoes rpm's? wheelhop?
Posts: 7,025 |
Originally posted by 97 SE: Originally posted by beyondloadedSE: dropping the clutch at 4K is def. not the way to pull a good 60 foot time. Seriously, all the guys that pull 2.0 60' times are revving at like 2,000-2500 rpms and slipping the clutch.
The engine would bog. Slip the clutch and floor it.
Jim Hahn
