Posts: 3,395 |
I have a computer with a Linksys Wireless B PCI card, and my friend and I want it to be able to connect to his network from my house to be able to be on a LAN. Problem is, im lucky to get a Wireless signal.... Is there a way I can modify my antenna to reach the WAP?
Posts: 2,542 |
well you can take a look at this site and make your own here or here but ive had wireless for a long time now and unless your gonna spend alot of money and get profesinal wirless routers and cards like the big companys do your gonna get disconnects i often loose the signil in my house in the same room it gets annoying sometimes i only use wirless when i need to i recomend buying some cat 5 cable and running either under ground (dig a shallow trench) or something like that yall are neighbors so it shoudn't take to much wire
Posts: 1,660 |
Originally posted by johnwilliams474: well you can take a look at this site and make your own here or here
If you can't maintain a wireless connection you need better equipment. I've got a Toshiba 802.11b router and a Hawking USB receiver/antenna and haven't dropped my household network in a year. I can also access several of my neighbors' networks too (though they're smart enough to keep them locked down so I can't get on they networks they show up with good signal strength).
You can build your own high-gain antenna or buy one to extend the range of your network. Either one will be easier and cheape than trying to run Cat5 cable to a neighbor...
Scott
Troll! '99 BMW 328i
Posts: 3,045 |
Originally posted by Pigeon:
If you can't maintain a wireless connection you need better equipment........and haven't dropped my household network in a year.
Scott
agreed and it is very easy.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 3,816 |
We are trying to get a network going in this dorm (I settled on using routers as APs out in the hallways using PoE so we didn't have to tap into anything) but the whole place has metal beams and stuff, so signal sucks.
I can't remember their name, but a friend found these small APs (the size of a plug in transfomer, so not big at all) that their whole purpose is to repeat the signal, probly a search on Google would be helpful?
EDIT: I just asked my friend, he says Linksys made them.
Posts: 3,395 |
Scott
I'd probaly need a repeater, the house im connecting to is 1 down, and across street
Im going to try and modify my antenna
Posts: 3,816 |
Well, I doubt those ones I mentioned will work in your case... I'd say the yagi (I didn't check out the link, but I'm assuming that's what they show plans for) antennas would work best... I aquired a DirecTV dish from helping a guy move... we put a yagi on it just to see if we could, it worked but it's way too akward for our use. I can just see the 1st sergeant coming in for a room inspection and seeing some ghetto dish antenna pointed inside the building (along with my wireless router, bridge, and nic with external 12" car antenna...). Heh, my friend has 5 wireless routers in his room, one of my wireless nics, plus a 1000' box of cat5 in there. Ok, I admit it, we're geeks
Posts: 1,957 |
NEED AN SVT REAR BUMPER!!! pm me
Posts: 246 |
Originally posted by Pigeon: Originally posted by johnwilliams474: well you can take a look at this site and make your own here or here
Scott
I am moving to a place that only has a wireless network in place. The router is in the other end of the apartment so I bought a Hawking hi-gain USB antenna for my P.C. Do you have good luck with it?
David
AIM: DaveL225
2002 CD Silver Focus SVT
2565/4788
Posts: 1,177 |
Originally posted by ContourKev: I have a computer with a Linksys Wireless B PCI card, and my friend and I want it to be able to connect to his network from my house to be able to be on a LAN. Problem is, im lucky to get a Wireless signal.... Is there a way I can modify my antenna to reach the WAP?
Scrap the wireless PCI card ... they are generally not very good at all. Get an external Wireless card that works off CAT5 cable, and not USB. You can then run a nice long CAT cable to position your wireless card.
That's the simplest solution .. but it may not work.
How far apart are your places ? Anything greater than 100' is going to have problems with home user hardware. Don't forget dense materials, such as stone, will hammer the signal, and overhead power lines will play havoc too.
Your best bet for a solid signal, is to get two VPN wireless firewalls. Then pull the regular antenna's and attach either higher gain antenna's if you are close enough, or directional antennas. If directional, you must point and adjust these, just like a satellite dish. This option will involve feeding the cable from inside to the outside of your house. It's not something you want to do if you will only use it for a short time.
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
