Page 2 of 2 1 2
#113377 02/04/02 11:40 PM
i have had the speedometer bouncing off of 160MPH mark. was at 6,400 rpm's. slowed down when i realized how fast i was going.
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
#113378 02/05/02 06:01 AM
It's getting a little thick here. Don't mind me while I find some higher boots.
Jim Johnson
98 SVT
#113379 02/05/02 06:28 AM
Hey Jim,
Let me give you a hand getting into those things.
Then you can help me get into my SCUBA suit.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#113380 02/05/02 06:31 AM
I believe Sam though... He's just insane... err... The extra 100 ponies help add credibility too... laugh
Closed track, professional driver got 143-144mph from a stock 98-99 SVT So add maybe a couple more mph for the most moded N/A SVT and it's maybe 150mph actual speed.
The speedo lies... It's just that simple.
Look at the speedo for your redline shifts once. 3rd to 4th and 4th to 5th. It's always above what the actual gearing would indicate.
RPM = Final Drive x 336 x MPH / Tire Diameter
Physics won't lie to you...
As for the numbers.
Those were an average of peoples reports of actual (via gps or obd-II) vs indicated in a few long threads a while ago. I personally think OBD-II under rates the actual speed myself as it is always noticeaby below what gearing would indicate
I think mine are likely a little more skewed do to the worn KDW's. (like I said maybe half tread left on the fronts - time to rotate again wink )
I still think they never changed the gear factor when they switched to the slightly smaller 215/50 vs the 205/55??? The larger tires always seem to be closer to actual across the board. 225/50's are in my future next spring... laugh
2000 SVT #674 - Check it out!
Page 2 of 2 1 2
