#1131998 12/15/04 11:48 PM
KenetiX Offline OP
Hey everyone, there was a post about this, but i couldnt seem to find it anywhere. So ill have to ask again, sorry.
I have a 1996 Contour (2.0L w/auto transmission). My instrument cluster is the basic one (with no tachometer). If i went to my scrap yard and picked up a 95-97 cluster with tachometer (from another 2.0L) would i be able to switch? Would it physically fit? And the second question is, can i remove my odometer from my old cluster and simply pop it in the new cluster? I am assuming the tachometer wiring would already be in place am i right? Or would i have to wire it up?
Thanks
Ken
96 Contour GL 2.0L 4banger w/auto tranny @ 218,800kms
#1131999 12/16/04 12:11 AM
E
E
The tach cluster from a 96-97 will work. The 95's have a cable driven speedometer. It bolts directly in and all the wiring conects. Start it and drive, everything will work, assuming you didnt grab a `95 cluster.
As far as changing the speedometer head, I am unsure. Mine was failing, so I didnt swap heads.
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
#1132000 12/16/04 12:31 AM
Should bolt up fine. (Next time, might want to post in general or general mods. Doesn't matter though ). Some cars do not have the tach cable, so you would have to run a cable from the ECU to the guage. This has all been discused before, should turn up in searches. Let me know how this goes, I also want to do this, but just haven't gotten around to it yet.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1132001 12/16/04 01:34 AM
it will work, but read into your local laws about odometer swap, usualy all you have to do is get a sticker that says the origional mileage on the swap and the origional miles on the doner cluster. Its pretty easy to do also.
#1132002 12/16/04 01:43 AM
W
W
There were three types of speedometers in the 95s. There were two cable driven and one sensor. My 3/95 had a sensor, not cable driven.
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
#1132003 12/16/04 02:08 AM
W
W
I just got done installing an autometer tach on my 98 contour. It went fairly easy, and if it was me, I would do that instead of changing out the whole cluster. Easier, and then you won't have to deal w/ the milage stuff!
Wijn
1998 tour Zetec B&G springs cut 1" 17" Amp "tech-9" rims Pro tint 2 1/4" exhaust Autometer tach & Euro Guages CTA/weapon R combo intake Zex Dry Nitrous kit
