Interesting about the requirement for two, it looks like tirerack will sell just one Koni. Though since I have no idea how old the koni's on the car are I wonder if replacing just one makes sense, or if I should replace both front ones.
Regarding adjusting, I didn't say it in that last post but had mentioned it at the begining, the koni I'm looking to replace is missing the adjusting nut on the top, that top area where it goes through the bolt is somewhat mangled and that side feels stiffer so I suspect the valve may be shut. Also when I purchased this car the tie rods inner and outer on that side (passenger side) had to be replaced as they had gotten the "sockets" (i think), all loose or stripped out.
I sent an email to Koni asking if these things have strut inserts, ie. does that outer sleeve, the piece with the collar and braces to attach to the car, come apart from the inside?
They had previously emailed me in regards to the adjusting bolt on the top with the idea that I contact tire rack to see about getting a new "strut insert"
