Page 2 of 2 1 2
#113150 01/30/02 05:31 AM
Ghosst,
Just one nit picking comment. The first year for the 200 HP engine was 1999. The 1998 1/2 (also known as E1) was still 195 HP.
Jim Johnson
98 SVT
#113151 01/30/02 05:48 AM
W
W
Originally posted by ScottK:
Close but not quite:
SVT has a SMALLER (19 IIRC)front sway to reduce understeer
SVT has more duration but the same lift
Valves are the same
filter is NOT K&N, it's Ford conical
Only late returnless SVT's (and Cougars) got larger lowers
SVT got 19# vs 17# injectors, not really heavy duty, just higher flow
front struts got reworked valving on E1's IIRC
lots of other things too:
higher capacity cooling system, oil cooler, PATS system, different motor mounts, different clutch lining, tigher inspection/selection process on the crankshaft, bigger front brakes
I still like my 97 SE with the stiffer (stiffest) springs and shocks better smile
As far as I know, all 99 SVT's returnless or not came with the larger Lower intake.
I have and early 99 with the larger lower and I have a return style.
It's pretty much accepted that the larger lower is the reason the 99 can hit 200HP, 5 HP more than the 98.
Just nitpicking though.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
#113152 01/30/02 07:13 AM
Jim and Warmonger:
nits have been picked...err...I mean, post edited.
#113153 02/01/02 05:13 AM
I own both an SVT and an SE. Recently I forgot which one I was driving and the SE nearly put me in the ditch. I was in SVT-mode, and the S-turns were a little more than the SE suspension and tires wanted to do.
The SE is pretty good with the V-6, but my SVT will eat its lunch anytime, IMHO.
Sidewinder: 1999 SVT
Thud: 1998 SE V-6
Edgecrusher: 1998 Mercury Mountaineer, 5.0L
#113154 02/01/02 05:42 PM
I thought the 2000 SVT's only had 200HP, like the 99's, not 205?
1996 Contour SE Red V6 MTX
1995 Contour LX Champaign V6 ATX (my wife's beater)
SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Page 2 of 2 1 2
