#113140 01/30/02 02:36 AM
SVT 2.5 V6 vs. SE 2.5 V6
whats the differnce?
by my observations difference in the two our: svt has differnt suspension, interior and exterior, but engine seems the same, but i knwo that cant be so soemoen turn the light on for me
#113141 01/30/02 02:41 AM
When someone yells and screams to use the search feature, just push it aside. Being new, you probably didn't notice it sitting at the top of the page.
The SVT has the following over the standard models:
- body kit
- better seats (they are Recaro in Europe, over here, they call them Ford)
- white-faced guages (higher speedo)
- no speed limiter
- smaller front anti-roll (sway) bar
- stiffer valving on the struts
- stiffer springs
- unique wheels
- higher compression (different pistons)
- longer lift cams
- polished (called Extrude Honed) intake manifold
- heavier duty fuel injectors
- larger lower intake manifold (late models)
- conical filter and less restrictive airboxes
- larger throttle body
- larger exhaust, split into two pipes at the tail
- lightened flywheel
- higher capacity cooling system
- oil cooler
- engine torque limiter
- larger front discs
- different clutch lining
- SVT Badges wink thanks for reminding me Chris...
FWIW, a regular Duratec (the name of the V6 engine) produces an average of 170bhp. The SVT engine produces an average of 195bhp on the E0 (98) and early E1 (98.5), 200bhp on the E1 (99), and 205bhp for the 2000.
A lightly modded SE/LX/GL can run the same or better times down low in RPMs as they are lighter than the SVT. However, once the engines hit their sweet spot (>3500rpm) the SVT will walk away.
The SVTs are fairly rare, although you will find a large number of SVT owners posting on this board. There are also quite a few of us with non-SVT Contours. You've come to the right place for help and ideas for your car, welcome aboard! laugh
#113142 01/30/02 02:42 AM
svt has bigger TB, extrude honed upper intake manifold and i think the 00's had a bigger lower, different cams, quasi dual exhaust, different intake filter, and i think extrude honed cylinder heads? did i miss anything?
Jim Hahn
1996 T-Red Contour SE
2002 Black Mazda MP5
Latest mods: sho shop off road y-pipe
#113143 01/30/02 02:46 AM
-----SOLD------
1995 SE Midnight Red V6 ATX
/////Alpine CDA-7876
Pioneer 6x8 3ways all around
Removed all badging and door guards
Infinity Perfect 12" powered by
RF 360a2
Sittin' Lower Konis and H&Rs
---BOUGHT----
Another Ford but I am not saying what!
#113144 01/30/02 02:49 AM
- no speed limiter
if the SE didn't have the limiter, anybody have an idea of what top speeds it would reach?
1995 se mtx. its all cool now.
#113145 01/30/02 02:51 AM
-----SOLD------
RF 360a2
---BOUGHT----
#113146 01/30/02 02:53 AM
Administrator
Administrator
SVT has "SVT" badges. That's about it. :p wink
-C
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#113147 01/30/02 02:58 AM
damnit I missed that one!
Thanks Chris!
#113148 01/30/02 02:59 AM
-C
the only thing that distiqueshes clark kent from superman is the glasses. hehe
Jim Hahn
#113149 01/30/02 03:38 AM
Originally posted by ScottK:
Close but not quite:
SVT got 19# vs 17# injectors, not really heavy duty, just higher flow
PATS system,
Post edited.
BTW, I have a PATS system and it's not an SVT...
Although it's really just a nit, I did just say "heavier", rather than heavy. I know they're not massive, but larger than ours at any rate.
Anyone have anything further to add? I'll edit my post accordingly and maybe we can have a consolidated list without the usual R&T or C&D crap in between.
