Page 1 of 3 1 2 3
Pole120 Offline OP
i've done a couple shore94 poly rear roll resistors for myself and customers, and figured i'ld guage intrest in a gb-heres how it will go if it happens(don't see why it wouldn't)
-for those of you unfamiliar with what i've done see this thread
>mounts will run $60 shipped plus a $40 core charge
>core charge does not apply to those that send me their mounts to fill in the first place(payment of $60 due uppon recipt of mount)
>those requiring a core pay the core charge of $40 at the time the order is placed, and final $60 due when mount is ready to ship(if i recieve a stock mount back, your core charge will be refunded)
*i believe these mounts will work only the V6 MTX tours\cougars-though i'm not sure(sopmeone can correct me if i'm wrong)
when listing your intrest please include wheather you will need a core or not
1) dion
I will be sending you my new mount this week.
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
Powdercoated?
CSVT Feels Like Heaven Goes Like Hell Profile
Pole120 Offline OP
yes, the housings are powdercoated
any chance you can get a metal tube that's the diameter of the through-bolt? I can't find one as thick as the stocker (just pipes and stuff). I'm not sure if there would be any negative affects from eliminating that play. Demonsvt was talking about using a smaller tube a year or so ago... not sure if he did it... or if anyone else has.
morbid 2000 Contour SVT (black)
Just so you know the pre98 mounts are much different. They have the bolts riveted to them. Make sure you tell ppl this is for post 98 only or you're going to have a bunch of MM you can't use as core for others.
I am sure you might know better then I but the pre98 one on my car looks just like the one in the pic and in all the catolog pics, but it was a zetec also but I thought the mount was the same for the 5spd setup?
edit: we are talking about the rear mount right?
Pole120 Offline OP
the stock tube is re-cast into the new mount, a machine shop prolly wouldn't charge you too much to have a tube turned to the diameters you want.
these are for post 98 only(thanks)
yes
9
the pre98 rear mounts are the same the front mounts are the different ones
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
I have my mounts ready to ship after xmas/new years, and am down for this GB for sure
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
Page 1 of 3 1 2 3
Moderated by  1314_dup1
