Posts: 1,746 |
I know the B&M Short Shifter is a "Direct Bolt-On" for the SVT Contour. Does it have the reverse Lock-out like the stock shifter? Or not? Any Information is appreciated.
2000 Contour SVT
SF - #542 of 2150
Posts: 2,033 |
Yes, the B&M shifter does have a reverse lock-out on it. But, I dont really see a use for, I have a B&M, and I disabled the reverse lock-out. But thats just me. But otherwise, yeah it does.
Posts: 111 |
I have the b&m also, the reverse lock out does not work for s**t. Anyways yes it does come with it.
'98 Black/Blue CSVT
-#162 D.O.B 4/12/97-
-----Many MODS-----
Posts: 4,051 |
The reverse lock out on B&M doesnt work at all for all E0's (or at least most from what I know). The shifter assembly is slighty different from 98.5-00 from what I understand. But it will work perfect with the additional of one small washer. Thats all it took to make mine work. It just needs to be placed under the little metal corner piece on the shifter base. It the piece that the shifter is supposed to hit if you try to shift to reverse without lifting the lockout. For some reason, on E0's, the metal corner on the base is too low and doesnt make contact but if you place a washer under it, it works fine.
Posts: 1,746 |
Originally posted by getlucky151: Yes, the B&M shifter does have a reverse lock-out on it. But, I dont really see a use for, I have a B&M, and I disabled the reverse lock-out. But thats just me. But otherwise, yeah it does.
It's basically there just in case I start day-dreaming and think I have a 6-speed. Which hasn't happened yet, but you never know. Thanks for the info everyone.
2000 Contour SVT
SF - #542 of 2150
Posts: 9,872 |
Originally posted by CSVT1214: The reverse lock out on B&M doesnt work at all for all E0's (or at least most from what I know). The shifter assembly is slighty different from 98.5-00 from what I understand. But it will work perfect with the additional of one small washer. Thats all it took to make mine work. It just needs to be placed under the little metal corner piece on the shifter base. It the piece that the shifter is supposed to hit if you try to shift to reverse without lifting the lockout. For some reason, on E0's, the metal corner on the base is too low and doesnt make contact but if you place a washer under it, it works fine.
dammn my car gets the shaft!!
Posts: 3,816 |
Originally posted by Goonz SVT: dammn my car gets the shaft!!
there is one in my car, with the lockout disabled...
Posts: 9,872 |
Originally posted by Kane: Originally posted by Goonz SVT: dammn my car gets the shaft!!
I like the reverse lockout though
Posts: 4,051 |
Originally posted by Goonz SVT: Originally posted by Kane: Originally posted by Goonz SVT: dammn my car gets the shaft!!
Goonz, it unbelievably easy to get reverse lockout to work on a E0. Takes a total of 2 mins to install the washer that makes it work. Hardest part of it is finding the right washer to fit.
I like my reverse lockout too. Plus I figured since it came with the car, I wanted to leave it that way.
Posts: 3,816 |
What does the reverse lockout do? (my old Contour was an auto)
There is a safety mechanism that prevents you from going from 5th to reverse still on the car (probly built into the tranny).
