Page 1 of 3 1 2 3
#112748 01/22/02 02:31 AM
Does anyone know what the differences are between the early and late SVT 2.5's? I know about the returnless fuel system and the longer stroke/smaller bore of the 2000's but other than that are their any differences between them? The reason I ask is because i would like to put a built up 2.5 in my SVT but i dont know if I'm better of getting a motor form the same year car or if it doesnt matter? Any help would be nice, thanks
'95 Mustang GTS, 11.3 @ 119MPH
'00 CSVT, 15.3 @ 91MPH
3L In The Works!!
#112749 01/22/02 05:36 AM
The 98 E0 and E1 are the same. The 99 has 5 more HP due to more agressive extrude honing of the intake. As you already know, the 2000 has slightly less displacement, but higher compression.
Jim Johnson
98 SVT
#112750 01/23/02 05:43 AM
Make me wish I had a 99 instead of a 98.... :rolleyes:
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
#112751 01/23/02 02:05 PM
Only smaller bore, stroke remains the same.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#112752 01/23/02 10:01 PM
All Duratec's have a 79.5mm Stroke
82.3mm bore pre 00
81.67mm bore 00 & on
for SVT's
10.00 CR pre 00
10.25 CR for 00
Done via different pistons...
2000 SVT #674 - Check it out!
#112753 01/24/02 05:45 AM
You fellows are incorrect about the change in displacment on the 2.5L.
All '99 and up 2.5 are actually 2.49L.
All '98 and earlier 2.5 are 2.54L.
#112754 01/24/02 06:01 AM
Ford's SVT Enthusiast magazine stated that the 2000 SVT had reduced the displacement to meet European standards. The same article says that the compression was raised from 10:1 to 10.25:1 to retain the 200 horsepower rating.
I have not seen any other publications about the change in displacement.
So the change in displacement was for the model year 2000 according to Ford. Does anyone have any evidence to the contrary?
Jim Johnson
98 SVT
#112755 01/24/02 07:48 AM
That you are definitely going to have to prove.
All factory service data says otherwise.
I might buy they changed over during the end of the 99 production run (since it was very late in being finished due to the strike) (Cougars especially)
Also the change to returnless happened late model year 99. IMO it's the same reason as above. I'd buy they changed both at the same time, but definitely NOT ALL 99's
The 99 SVT's have the larger bore for certain.
#112756 01/24/02 12:16 PM
Oh man, more arguing on this. It seems that we always have conflicting sources on this, but Ford says 195 for 1998, and 200 for 1999+. There was rumors of a 205hp rating for 2000, but was this ever confirmed?
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#112757 01/24/02 01:46 PM
oh no.. not the 205 thing again. :rolleyes:
Page 1 of 3 1 2 3
