Posts: 7,025 |
None of the final runs were done on ice or even exchanging out the hot water in the intercooler resevoir so I think I could squeeze a little bit more hp at this psi. Dave said there was a small oil leak on the rear valve cover so 8 psi was as high as they went. Btw, on 4 psi the whp was 258 whp (dont know the tq since they didnt give me a printout). It probably wont be until the summer until I get the rest tuned for higher psi levels. Money is getting tight. Discuss.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
CEG road warrior
CEG road warrior
Posts: 17,248 |
Nice numbers indeed!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 5,143 |
your max power was at 3200 RPM's? Talk about low end torque...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ALIAS Jerk: your max power was at 3200 RPM's? Talk about low end torque...
I was thinking the same thing....talk about spinning the tires no matter what!
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,097 |
Lookin good...I wish you the best of luck tuning...how much boost are you planning to run?
98 E0 SVT with some stuff
Posts: 7,025 |
Originally posted by stilov: Lookin good...I wish you the best of luck tuning...how much boost are you planning to run?
probably 15-17...basically whenever the turbo stops making power.
Jim Hahn
Posts: 2,097 |
interesting...what turbo are you running? Let me guess t3/4 .57 trim with 48 A/R? Just a guess...also when are your 2ndaries opening?
Posts: 1,516 |
Wow that's perfection! A/F ratio  Very very nice numbers!
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
Posts: 4,713 |
Very nice lookin' curves, Jim. Very nice indeed.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 1,346 |
E1 CSVT
s/c-----x
turbo---x
3L------check
