Page 1 of 5 1 2 3 4 5
#1127410 12/11/04 03:12 PM
None of the final runs were done on ice or even exchanging out the hot water in the intercooler resevoir so I think I could squeeze a little bit more hp at this psi. Dave said there was a small oil leak on the rear valve cover so 8 psi was as high as they went. Btw, on 4 psi the whp was 258 whp (dont know the tq since they didnt give me a printout). It probably wont be until the summer until I get the rest tuned for higher psi levels. Money is getting tight. Discuss.
CEG road warrior
CEG road warrior
Nice numbers indeed!
your max power was at 3200 RPM's? Talk about low end torque...
CEG road warrior
CEG road warrior
I was thinking the same thing....talk about spinning the tires no matter what!
Lookin good...I wish you the best of luck tuning...how much boost are you planning to run?
98 E0 SVT with some stuff
probably 15-17...basically whenever the turbo stops making power.
interesting...what turbo are you running? Let me guess t3/4 .57 trim with 48 A/R? Just a guess...also when are your 2ndaries opening?
Wow that's perfection! A/F ratio
Very very nice numbers!
Mazda 6S, V6, Speed Yellow 5 Speed, Sport package Bose audio Painted 'stash and HIDs! w/Injen 1/4 14.750 @ 94.94 Former car: 99 Contour SE Sport Black MTX V6 SVT plastic... 1/4 - 15.012 @ 90.58
Very nice lookin' curves, Jim. Very nice indeed.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
I
I
me likey....me likey
E1 CSVT s/c-----x turbo---x 3L------check
Moderated by  mbb41_dup1
