#1126757 12/10/04 04:58 AM
In case people haven't seen the latest Fusion spyshots
Here you go.
George Hodge New: Volvo S60R Old:2000 SVT Silver Frost 1188/2150 DMD, 75mm Pro-M, HPP rear strut tower bar Aussie 24mm sway bar (with boxed in subframe) BAT European Handling Kit, Brullen Y-pipe Performance Ford spherical bearing end links
#1126758 12/10/04 01:19 PM
N
N
That's a pretty nice looking little car.
#1126759 12/10/04 01:42 PM
Very stately. Rather have a Mazda 6s.
#1126760 12/10/04 02:52 PM
Very nice... looks like they are using some Caddy design cues with the front fenders.
Now, the big question is what type of powertrain will it have? As a 2006 model, with the 3.5 finally be available? That should be the BASE engine with an updated 3.9/4.x V8 from the LS as the optional powerplant.
1998 SVT Contour E1, Black (Mine) - Winter 3.0 Project 2004 Sentra SE-R SpecV (Wifes) www.SuperHawkForum.com
#1126761 12/10/04 02:58 PM
W
Back In Black
Back In Black
W
3L v6 200hp
1999 Black-N-Tan SVT Contour #291 Check out CD338.com:: The Premier Ford Fusion Site!
#1126762 12/10/04 03:11 PM
3L v6 200hp
#1126763 12/10/04 03:13 PM
3L v6 200hp
The 3.0 liter engine in the X-Type is a duratec, right? Why can't they use that motor as optional power in the 500 and the Fusion?
2005 Subaru Legacy | Ban Them Forever
#1126764 12/10/04 03:18 PM
Because it only has 23 more hp. Probably costs more to produce.
#1126765 12/10/04 04:59 PM
I am not too excited about the looks of the front end, but perhaps a 2007 will be in my future if I can keep my 'tour on the road that long. By then I should be pushing well over 150K.
2000 Contour SE Sport Originator of the Beowulf Headlight Mod and the Beowulf CAI
#1126766 12/10/04 05:11 PM
The new K-1 Attack has a 240hp 3L Duratec, the Bonspeed X-Type has a 260hp 3L Duratec. So the power is easily there -- as most us here know. But if Ford wants, it's much easier and cheaper to squeeze power out of the 3.0L than it is to upsize the engine.
The 3.5L Duratec will be coming in 2007 -- along with the Mazda6 redesign at the same time. Whether it will be going on the 500/Futura at the same time, I don't know, but I would imagine so.
As for why not the V8? Because 300hp on a mid-size FWD econo-sedan just spells wheel-hop, torque-steer, and front-end plow. It'd drive like a pig and require extensively upgrading the entire drivetrain to handle that much power, because I doubt this car is made to handle 300+hp, a full 50% more over stock, right from the factory.
2003 Mazda6s 3.0L MTX Webpage
2004 Mazda3s 2.3L ATX
