Page 2 of 3 1 2 3
F
F
hey man you seem pretty nice do you come online often so if I have any questions during the process you can answer them? I will be doing this within a week or so.
USMC training begins on the 25th of Jan wish me luck.
5
i think you are just lucky that i happened to stumble across the 3L forum with one eye barely open...
the 3.0L oval port 3.0L '98 midnight blue se
The only home made fuel rail I know of. Terry did Jd's and mine.
One made by Terry
Brazed fuel rail.
http://www.fototime.com/CEA8663E94D0658/standard.jpg
http://www.fototime.com/FAF2BF14234F369/orig.jpg
http://www.fototime.com/08B117EDCCEAC3B/orig.jpg
I hope to god you have done a lot of research. Don't say JD and I didn't warn you. THIS ISN'T SOME EASY OVER NIGHT SWAP. Think of bad scenario and X it by 5.
F
F
brazzing a fuel rail is basically makin it 3.0L compatable right?
No 4.6 compatable.
F
F
ok how about this... would it be tons easier to just do a 2000 contour engine vs a 3L? I am at the point where I dont care about performance I am happy with the contours abilities... maybe I'll throw on a torsen and headers or something I just no longer want to deal with the 3L lol.. I am a FLIP FLOPPA. Is it a ton easier to just put in a new 2.5 the 97 cant be too differant than a 2000 right? I know the differant 3L's after weeks of research but I guess I never thought about the differing 2.5's am I going to run into just as much work as swapping a full 3.0L? I personally wouldnt think so but uhh.. help im rambling. any help is appreciated. -Jesse
Y
Y
Well you have to figure out what the hell it is you want. If you're talking a FULL 2000 Contour motor swap, then think again. There are more differences than you think, ie: returnless vs return style, vacuum IMRC v Electric.. If your motor is blown, then a straight block swap should be no problem, or you could just rebuild the block you have for even less, depending on damage. But then again, you say you already have the 3L? I'd think for $750, you could find someone to do the modification to the fuel rail and any other misc mods that you/your brother can't do. But don't think you're going to have this done in a matter of 2-3 days.. Best bet is to have your 3L prep'd and all fuel rail issues figured out before swapping, so you can pull the 2.5L and get to installing the 3L without having much downtime with missing parts.
Mark
Originally posted by Flemloid - -:
Oh one more thing... whats the whole brazzed fuel rail thing? Sorry if I sound REALLY nooby.
A bad idea for the most part. Even with it professionally done it still risks high pressure leaking.
By far your best bet is to fabricate the lines & connections. Though with the older fuel rail that may be harder then it sounds.
Fuel injection hose is cheap and the fittings should not cost much.
Plus it is much safer then risking a high pressure fuel leak on top of the hot engine.
Being a 95 you are going to have to fabricate everything anyway. (old fuel rail & injectors)
What did you do about the IMRC wiring?
Have you figured out a way to keep the PCM from tripped a CEL?
95 is pretty alien to me. Vacuum operated with, what I would guess to be, trip switches to the OBD-I PCM.
I would expect you will have to make some kind of rpm relay switch to fool the PCM into thinking the IMRC is operating normally.
Hey at least you don't have to fool it into thinking the IMRC box is there because it never was...
F
F
hey guys I better say this again... its got a 97 engine in it currently so the only thing 95 about is the body/drivetrain
F
F
Y2KSVT, I like your idea... but I dont wanna dismantle any engine period. I dont have an engine yet... just 1200 dollars and hopes and dreams lol. Dont get me wrong I am very interested in doing this RIGHT not just a quick stupid job. I dont need my only car exploding or something on me. remeber 97 engine no vacuume powered butterflies hehe. So far You guys are being pretty nice. I love this site.
Page 2 of 3 1 2 3
