CAMLRDR Offline OP
ok well i have 2 400wrms pioneer 10s in the trunk with a 700w amp now i just bought a kicker cvr10 and im thinking of putting it inside of the car like in the backseat area..any suggestions for mounting or placement..i was thinking just to build a box to specs and just keep it in the backseat till i find a permanant home for it..
NEW RIDE: 93 NON TURBO SUPRA Black/Blue pearl 97 V6 GL Duratech 5%tint around survivor kit 2 10" 450w pioneer subs and tv kenwood 3way 300w speakers air ride 18's intake my cardomain
This may just be my opinion since I work in the car audio theft investigation/replacement industy.
DONT DO IT
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
DONT DO IT
Word. The only thing I can think of if you want to keep space for the trunk is door mount (like the Illusion Audio ND series) or a custom install, the only place which I have really looked at is the cupholder area and the console under the armrest.... that would be a lot of work and expensive, but it's a good alternative to taking up the trunk.
1998 Contour GL 2.0L Zetec Stock as hell for the moment....
CAMLRDR Offline OP
i dont care abotu trunk space since i have my airsuspension tank and 2 subs already in there and im building a custom box in the wheel well where the box will be in the ground but i just wanted to do sumthing diffrent..im not worried abotu car theft becuase i am gonan buy the best alarm i canfind before i instlal the sub and my tint is 5 percent and u cant see shiet..my car stays in a garage at home and the security gaurd parks his golfcart next to my car at school so im not really worried about theft.
ok, here ie a tip: Make use of your space. Buy a single good sub and put it in either an ABC box or a factory recommended ported box, depdending on what you want. If you want SQL, go with the ABC, pure SPL, go ported.... if you need any advice for anything good, just ask around on here, especially CarpePoon, he knows his shiz....
H
H
I'm thinking, if you don't care about the trunkspace, get rid of the 10s, all of them, and get a really good 15" driver and mount it in a tuned ported box. With it's cone area alone it would kick the tens asses for SPL, and that's talking one 15 vs. two 10s (althouh a really nice 15 will more than likely get as loud as everything you plan on tossing in your trunk) A single 15 will also be easier to get sounding really good since you aren't mixing different equipment with different abilities.
The more different equipment you start tossing in there the harder it will be to make it sound good. Loud is great, but noisy gets old real fast. So says the guy that once had 14 speakers in his Contour, and has since gone down to 7 (custom 3 way front components, and a 15" sub) The scary part is that by choosing better equipment, less drivers are more capable than the wagonload I had.
2003 Ford Focus ZX3 "Tarmac" http://www.cardomain.com/ride/2352003
i only have five speakers.
Seven!?!?
2 Tweets, 2 Mids, & 1 Sub - all I ever use.
Been pondering a PR sub system in my MSP. Will the 1 or 2 PR's count as "drivers"?
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
1400w quantam amp
I think you should try upgrading this stuff first before adding on. Otherwise its kind of like adding on to a mobile home.
Did you ever fix the problem you created with your existing system???
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=audio&Number=711048&Forum=All_Forums&Words=18077&Match=Username&Searchpage=2&Limit=25&Old=allposts&Main=711048&Search=true#Post711048
If I remember correctly, that sub box you slapped together was about 1/3 the size it needed to be. If you didnt fix this yet it would be STOOOPID to buy another sub.
H
H
Originally posted by cthomp21:
Seven!?!?
Passive radiators don't count, or else I would count ports too (my current box has a few tiny ports I can't seem to pinpoint so I destroyed it) I was contemplating a PR system too, but with the ED subs the ported box is tiny (2.2) so it's not really necessary.
Up front I have the 7" Vifas, I'll have the BG Planars back in the kicks with them, and playing from 8000 up the tweeters in the pillars.
I could have gone with just 5 speakers, but not using these Neo8s would be such a waste
Moderated by  dnewma04_dup1
